1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget?
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "D. Peter Siddons" <[email protected]>
Date: Mon, 16 Mar 2020 18:18:35 +0000
>  I would like to display the intensity graph with the intensity on a log scale. I don't see a way to do that. The XY graph has that capability, but not the intensity graph. Is there a way to achieve this. I don't want to have to do it in the IOC if I can avoid it.
Check for "Log. Scale" in the "Behavior" section of the image widget properties.
Re: [EXTERNAL] Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Kasemir, Kay via Tech-talk
How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Chiang, Liang-Chih [江良志] via Tech-talk
Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? D. Peter Siddons via Tech-talk
Prev: Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? D. Peter Siddons via Tech-talk
Next: Re: [EXTERNAL] Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
