Subject: Re: monitors on array variables
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "D. Peter Siddons" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 19 Mar 2020 08:35:21 -0700
On 3/19/20 7:51 AM, D. Peter Siddons wrote:
> Hi Michael,
>    I tried that and it didn't change anything. However, I discovered that accessing some variables from the iocsh gave different results from caget, so I must have some name confusion in my code. Thanks for your help, at least I discovered this!
You don't by chance have more than one instance of this IOC running?
Or otherwise have two IOC instances serving the same record names?
> Pete.
> On 3/18/20 6:25 PM, Michael Davidsaver wrote:
>> FYI. passing NULL instead of a field address to db_post_events()
>> will post to every subscription on the record regardless of field.
>> Trying this should give a clear indication if the only problem is
>> the wrong field address.
>> I guess the other variable is event mask.  SO
>>> db_post_events(pscal,NULL,0xf);
>> should post to every subscriber to this record regardless of field or mask.
>> On 3/18/20 12:02 PM, Mark Rivers wrote:
>>> Could this be a problem with EPICS_CA_MAX_ARRAY_BYTES?  What if you do:
>>> camonitor -#20  det1.SPCT
>>> ________________________________
>>> From: Siddons, David <[email protected]>
>>> Sent: Wednesday, March 18, 2020 1:51 PM
>>> To: Mark Rivers; Michael Davidsaver
>>> Cc: EPICS Tech-Talk
>>> Hi Mark,
>>> Yes, I did that. THis is essentially an expanded scaler record. In updateCounts I have:
>>>         Debug(5, "updateCounts: posting scaler values %d\n",0);
>>>         /* copy and post spectrum values */
>>>         for (i=0; i<4096; i++) {
>>>                 if (mca[4096*pscal->monch+i] != spct[i]) {
>>>                       spct[i]=mca[4096*pscal->monch+i];
>>>          db_post_events(pscal,&pscal->mca,DBE_VALUE);
>>>          db_post_events(pscal,&pscal->tdc,DBE_VALUE);
>>>          db_post_events(pscal,&pscal->spct,DBE_VALUE);
>>> etc,
>>> It gives this output:
>>> ../zDDMRecord.c(818):updateCounts:   called by process()
>>> ../zDDMRecord.c(830):updateCounts: got counts[] 0
>>> ../zDDMRecord.c(838):updateCounts: posting scaler values 0
>>> ../zDDMRecord.c(866):updateCounts: exit 0
>>> Running camonitor on det1.SPCT reads the initial values and waits. Triggering a change (by changing monch) results in nothing. It just sits there. I can verify that the values have changed by doing a caget, or a dbgf on the console:
>>> peter@peter-Latitude-E7240: ~/$ caput det1.MONCH 0
>>> Old : det1.MONCH                     5
>>> New : det1.MONCH                     0
>>> peter@peter-Latitude-E7240: ~/$ caget det1.SPCT[1:20]
>>> det1.SPCT[1:20] 20 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>>> peter@peter-Latitude-E7240: ~/$ caput det1.MONCH 5
>>> Old : det1.MONCH                     0
>>> New : det1.MONCH                     5
>>> peter@peter-Latitude-E7240:~/$ caget det1.SPCT[1:20]
>>> det1.SPCT[1:20] 20 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100
>>> I guess I'm doing something dumb, but I can't see it.
>>> Pete.
>>> From: Mark Rivers <[email protected]>
>>> Sent: Wednesday, March 18, 2020 2:25 PM
>>> To: Siddons, David <[email protected]>; Michael Davidsaver <[email protected]>
>>> Can you put some debugging to be sure db_post_events is actually being called, while at the same time running camonitor to see if gets an update?
>>> Sent: Wednesday, March 18, 2020 1:09 PM
>>> To: Michael Davidsaver; Mark Rivers
>>> Cc: EPICS Tech-Talk
>>> .....and I have, in cvt_dbaddr():
>>>   case zDDMRecordSPCT:{
>>>       paddr->pfield = (void *)(pzDDM->pspct);
>>>       paddr->no_elements = 4096; /* One spectrum for real-time display */
>>>       paddr->field_type = DBF_LONG;
>>>       paddr->field_size = sizeof(int);
>>>       paddr->dbr_field_type = DBR_LONG;
>>>       break;
>>> Pete.
>>> From: Michael Davidsaver <[email protected]>
>>> Sent: Wednesday, March 18, 2020 12:54 PM
>>> To: Mark Rivers <[email protected]>; Siddons, David <[email protected]>
>>> On 3/18/20 9:47 AM, Mark Rivers wrote:
>>>>> by analogy waveformRecord has
>>>>>> db_post_events(prec, &prec->val, monitor_mask);
>>>>> note 'val' not 'bptr'.
>>>> The mca record has worked with no changes in 3.14, 3.15, and 7.0.3 with these lines:
>>>> mcaRecord.dbd:
>>>> recordtype(mca) {
>>>>         include "dbCommon.dbd"
>>>>         field(VERS,DBF_DOUBLE) {
>>>>                 prompt("Code Version")
>>>>                 special(SPC_NOMOD)
>>>>                 initial("1")
>>>>         field(VAL,DBF_NOACCESS) {
>>>>                 prompt("Value")
>>>>                 special(SPC_DBADDR)
>>>>                 pp(TRUE)
>>>>                 size(4)
>>>>                 extra("void *val")
>>>>         field(BPTR,DBF_NOACCESS) {
>>>>                 prompt("Buffer Pointer")
>>>>                 special(SPC_NOMOD)
>>>>                 interest(4)
>>>>                 size(4)
>>>>                 extra("void *bptr")
>>>> mcaRecord.c:
>>>>     if (MARKED(M_VAL)) db_post_events(pmca,pmca->bptr,monitor_mask);
>>>> So it is posting monitors on the bptr field, not the val field, and it seems to work fine.
>>>> It looks like Pete is doing what the mca record does, but it is not working.  Why?
>>> Ah, there is a second piece to the puzzle.
>>> db_post_events() must be called with whatever address is in DBADDR::pfield
>>> which by default in this case is '&val' but this can be changed in the
>>> cvt_dbaddr callback.  Indeed waveformRecord used to do this.
>>> https://github.com/epics-base/epics-base/commit/92d52cc415599b7dffa7df1f23d5ba8227fb4d3a
Re: monitors on array variables D. Peter Siddons via Tech-talk
monitors on array variables Siddons, David via Tech-talk
Re: monitors on array variables Michael Davidsaver via Tech-talk
Re: monitors on array variables Siddons, David via Tech-talk
Re: monitors on array variables Mark Rivers via Tech-talk
Prev: Re: monitors on array variables D. Peter Siddons via Tech-talk
Next: Re: error calling dbGetLinkValue in EPICS base-3.15.6 Johnson, Andrew N. via Tech-talk
Next: Re: monitors on array variables D. Peter Siddons via Tech-talk
