Subject: Re: support for CryoStream 800? (Jemian, Pete R.)
To: "Jemian, Pete R." <[email protected]>
Date: Mon, 23 Mar 2020 11:10:32 -0700
Forgot the DB and req!
On Mon, Mar 23, 2020 at 11:09 AM Jemian, Pete R. <[email protected]> wrote:
Thanks!
  Pete R. Jemian, Ph.D.                <[email protected]>
  Beam line Controls and Data Acquisition
  Advanced Photon Source,   Argonne National Laboratory
  Argonne, IL  60439                   630 - 252 - 3189
     Education is the one thing for which people
        are willing to pay yet not receive.
From: Tech-talk <[email protected]> on behalf of David Vine via Tech-talk <[email protected]>
Sent: Monday, March 23, 2020 1:06 PM
To: [email protected]
Hey Pete,
i've attached a stream support for the 800.
Best,
David
On Mon, Mar 23, 2020 at 10:00 AM <[email protected]<mailto:[email protected]>> wrote:
Send Tech-talk mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. RE: database "diff" (Mercado, Ronaldo (DLSLtd,RAL,LSCI))
   2. support for CryoStream 800? (Jemian, Pete R.)
   3. detecting remote PV disconnect (asyn) (Hinko Kocevar)
   4. Re: detecting remote PV disconnect (asyn) (Mark Rivers)
   5. Re: detecting remote PV disconnect (asyn) (Hinko Kocevar)
---------- Forwarded message ----------
From: "Mercado, Ronaldo (DLSLtd,RAL,LSCI)" <[email protected]<mailto:[email protected]>>
To: "'DiMonte, Nicholas'" <[email protected]<mailto:[email protected]>>, Paul Sichta <[email protected]<mailto:[email protected]>>
Cc: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Bcc:
Date: Mon, 23 Mar 2020 09:52:03 +0000
Subject: RE: database "diff"
Hi.
I don’t use VDCT or GDCT, only epics databases.
I built a linux tool (attached) to compare databases using the parser from epics base.
I hope it’s useful.
I found that it only works for old versions of epics (3.14.12.x) because the dbStaticHost library is no longer built in epics base.
(Why not?)
To build, edit the makefile to point to epics base also edit ‘scompare.conf’ to point to your paths,dbd files and db files.
The ‘path’ line accepts colon separated folders. I generally use it like that, listing the dbd and db folder for my iocs.
Ronaldo
From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of DiMonte, Nicholas via Tech-talk
Sent: 20 March 2020 22:35
To: Paul Sichta <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]>
Subject: Re: database "diff"
Paul,
At the APS we had GDCT modified to add convert function to VDCT. The conversion maintained the graphical layout which was really nice. We only have a Solaris build if my memory serves me right.
Andrew Johnson might be able to help you get a copy of this version.
Nicholas D.
On 3/20/20 1:44 PM, Paul Sichta via Tech-talk wrote:
We're converting our (~200) databases from gdct to vdct.  After we drag around the records in vdct to visually arrange the linked records, we want to perform a final check to compare the original and the vdct records. We plan to write a text processing program/script to do this,  but...
Has anyone made a tool to compare the records and their fields in two database files?  Is there a utility (in the IOC) to dump a database report that we can compare (before/after)?  Does the old dbreport extension provide reports that list a record's field information that we can compare?
We're doing this because gdct doesn't run on Linux (right?).
-ps
From: "Jemian, Pete R." <[email protected]<mailto:[email protected]>>
To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Cc:
Bcc:
Date: Mon, 23 Mar 2020 15:11:42 +0000
Subject: support for CryoStream 800?
Anyone have support for the CryoStream 800?  Ethernet-based.  Thanks!
  Pete R. Jemian, Ph.D.                <[email protected]<mailto:[email protected]>>
From: Hinko Kocevar <[email protected]<mailto:[email protected]>>
Cc:
Bcc:
Date: Mon, 23 Mar 2020 16:11:44 +0000
Subject: detecting remote PV disconnect (asyn)
I have an EVR PV that delivers timestamp to my asyn based DAQ IOC. I want to know if and when that PV is inaccessible - i.e. EVR IOC not running / died.
I have this DB construct:
# get timestamp from EVR event PV
# i.e. set TSEL: LAB-EVR-004:EvtECnt-I.TIME CP MS
record(stringin, "$(P)$(R)TimestampIn") {
    field(DTYP, "Soft Timestamp")
    # use dummy placeholder PV, change EVR prefix to a desired EVR IOC
    field(TSEL, "LAB-EVR-000:EvtECnt-I.TIME CP MS")
    field(INP,  "@%s.%f")
    field(FLNK, "$(P)$(R)Timestamp.PROC PP MS")
    info(autosaveFields, "TSEL")
# holds TS value in 'sec.nsec' format
record(stringout, "$(P)$(R)Timestamp")
    field(DOL,  "$(P)$(R)TimestampIn")
    field(OMSL, "closed_loop")
    field(DTYP, "asynOctetWrite")
    field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))SIS8300.EVR.TIMESTAMP")
Works as expected. The $(P)$(R)Timestamp is refreshed upon each update of the LAB-EVR-000:EvtECnt-I PV, feeding the value to the asyn based IOC code.
Upon killing the EVR IOC the $(P)$(R)TimestampIn and $(P)$(R)Timestamp show no apparent state change that the LAB-EVR-000:EvtECnt-I went away. At least looking that the "dbpr ... 4" output for the above mentioned PVs.
I was expecting the alarm fields to be set to something like "not connected". Is there a way, in asyn based IOC, to detect this situation?
Hinko
From: Mark Rivers <[email protected]<mailto:[email protected]>>
To: Hinko Kocevar <[email protected]<mailto:[email protected]>>
Cc: tech-talk <[email protected]<mailto:[email protected]>>
Bcc:
Date: Mon, 23 Mar 2020 16:37:19 +0000
Subject: Re: detecting remote PV disconnect (asyn)
Hi Hinko,
I'm not sure of the configuration.  Is this correct:
- Both $(P)$(R)TimestampIn and $(P)$(R)Timestamp are in the same IOC.  That is not the IOC you are killing.
- The TSEL link is talking to another IOC (the EVR IOC), PV="LAB-EVR-000:EvtECnt-I.TIME CP MS"
- Is the OUT link is talking to a local driver?  What does this driver do?  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))SIS8300.EVR.TIMESTAMP")
Does TimeStampIn record ever go into alarm state when the EVR IOC shuts down?  It may take the time that the OS requires to detect that a socket is closed, which can be many minutes.
It seems to me that the record that should first detect the problem is not using asyn, it is the TimestampIn record.  So this is really not an asyn question, it is the behavior of EPICS base in general for CP links.
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Hinko Kocevar via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Monday, March 23, 2020 11:11 AM
To: [email protected]<mailto:[email protected]>
Hinko
To: Mark Rivers <[email protected]<mailto:[email protected]>>
Bcc:
Date: Mon, 23 Mar 2020 16:55:41 +0000
Hi Mark,
These live in the DAQ IOC, not EVR IOC (which I'm killing).
Yes LAB-
EVR-000:EvtECnt-I.TIME is on EVR IOC. Using MS flag there makes me think that alarm severity would be propagated to the record holding TSEL (I have never done this before so I might be wrong on this assumption).
Yes, OUT is local to an asyn driver (DAQ driver). Asyn code for DAQ driver takes the value obtained from EVR IOC PV and writes it to the firmware on top of which the DAQ IOC sits.
I do not think so. I've been looking at the "dbpr TimeStampIn 4" and none of the fields change value when comparing alive EVR PV vs dead EVR PV.
True. The first record is no using asyn.
Is there a way to check that the EVR PV disappeared?
//hinko
Hinko
Tech-talk mailing list [email protected]<mailto:[email protected]>
[https://static1.squarespace.com/static/56de1f4a2fe1318cf0aacc98/t/5d9e0fa57996446a078a8e1a/1570639781104/Logo_gmail_small.png?format=300w]
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Attachment: oxcryo.db
Description: Binary data
Attachment: oxcryo.req
Re: support for CryoStream 800? (Jemian, Pete R.) David Vine via Tech-talk
Re: support for CryoStream 800? (Jemian, Pete R.) Jemian, Pete R. via Tech-talk
Prev: Re: support for CryoStream 800? (Jemian, Pete R.) Jemian, Pete R. via Tech-talk
Next: Re: monitors on array variables Mooney, Tim M. via Tech-talk
Next: P4P, PVA, and PyQt Michael Davidsaver via Tech-talk
