1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: detecting remote PV disconnect (asyn)
From: Hinko Kocevar via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 25 Mar 2020 11:28:59 +0000
> Alarms should be propagated because the SDIS link is read with dbGetLink().
Using your record indeed propagates the alarms.
Thank you,
//hinko
Sent: Tuesday, March 24, 2020 6:36 PM
To: Hinko Kocevar
Cc: Mark Rivers; tech-talk
On 3/24/20 2:03 AM, Hinko Kocevar wrote:
> Michael,
>>> Yes LAB-
>>> EVR-000:EvtECnt-I.TIME is on EVR IOC. Using MS flag there makes me think that alarm severity would be propagated to the record holding TSEL (I have never done this before so I might be wrong on this assumption).
>> Normally yes, but .TIME is handled as a special case, so I wouldn't be surprised
>> if this didn't work.  I'd recommend using an additional longin record to subscript
>> to the value of the event Cnt-I PV.  Then forward link from this to your records.
> I'm after the timestamp of the Cnt-I record. I'm not sure I understand how to go about and implement your proposal.
Actually, thinking about it further, you can do:
record(stringin, "$(P)$(R)TimestampIn") {
    field(DTYP, "Soft Timestamp")
    field(SDIS, "LAB-EVR-000:EvtECnt-I CP MS") # not .TIME
    field(DISV, "-1")
    field(TSEL, "LAB-EVR-000:EvtECnt-I.TIME CA") # not CP
    field(INP,  "@%s.%f")
    field(FLNK, "$(P)$(R)Timestamp.PROC PP MS")
    info(autosaveFields, "TSEL")
This will work so long as the remote PV never has the value -1,
which an event counter should not.
Then, so long as the value read is !=DISV the record is scanned.
The TSEL link, as a regular CA_LINK, is fetching time from the last received update.
detecting remote PV disconnect (asyn) Hinko Kocevar via Tech-talk
Re: detecting remote PV disconnect (asyn) Mark Rivers via Tech-talk
Re: detecting remote PV disconnect (asyn) Hinko Kocevar via Tech-talk
Re: detecting remote PV disconnect (asyn) Michael Davidsaver via Tech-talk
Prev: P4P, PVA, and PyQt Michael Davidsaver via Tech-talk
Next: Re: detecting remote PV disconnect (asyn) Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: detecting remote PV disconnect (asyn) Michael Davidsaver via Tech-talk
Next: Re: detecting remote PV disconnect (asyn) Mark Rivers via Tech-talk
