1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Filtering messages print on the IOC shell console
From: "Paduan Donadio, Marcio via Tech-talk" <tech-talk at aps.anl.gov>
To: Ben Franksen via Tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 26 Mar 2020 19:57:29 +0000
We have some modules at SLAC that print tons of messages on the console when something gets wrong. When implemented through Asyn or Stream Device there are ways to reduce or cut off the messages, but some modules implement everything with printf or errLogPrintf.
It is a long shot, but do you think that there is a way to modify the IOC shell layer to verify a message before it is printed, even when printf is used?
Or, did anyone have a better idea other than to modify every module, changing printf and errLogPrintf to something else?
Thank you,
Márcio Paduan Donadio – Control Systems Engineer
SLAC – Stanford Linear Accelerator Center
Re: Filtering messages print on the IOC shell console Ben Franksen via Tech-talk
Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
Prev: Re: PV Access Ben Franksen via Tech-talk
Next: Re: Filtering messages print on the IOC shell console Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: PV Access Marty Kraimer via Tech-talk
ANJ, 26 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
