Subject: Re: Newport DL325
To: Igor Kriznar <[email protected]>
Date: Tue, 31 Mar 2020 18:01:28 +0000
Hi Igor,
It looks like they are only supporting the DL Single-Axis Motion Controller for those stages.
The User Manual documents the command syntax: https://www.newport.com/mam/celum/celum_assets/resources/DL_-_Controller_Users_Manual.pdf?1
The command syntax is very similar to the Newport AG_CONEX controllers, for which there is an EPICS driver.
https://github.com/epics-motor/motorNewport/blob/master/newportApp/src/AG_CONEX.cpp
You may be able to use the AG_CONEX driver, or you may have to write a new driver starting with that one but modifying the commands and syntax a bit.
From: Tech-talk <[email protected]> on behalf of Igor Kriznar via Tech-talk <[email protected]>
Sent: Tuesday, March 31, 2020 8:27 AM
To: [email protected]
Subject: Newport DL325
is motor record working with Newport DL325 (a Delay Line Stage) with DL
Controller?
Thanks!
Best regards, Igor
Newport DL325 Igor Kriznar via Tech-talk
Prev: EPICS7 roller-coaster Rolf Keitel via Tech-talk
Next: Re: EPICS7 roller-coaster Michael Davidsaver via Tech-talk
Prev: Newport DL325 Igor Kriznar via Tech-talk
Next: Re: Newport DL325 Mark Rivers via Tech-talk
