1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Setting an array to zero length
From: Ben Franksen via Tech-talk <[email protected]>
To: "Rogers, Will (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Apr 2020 15:33:38 +0200
Am 03.04.20 um 15:04 schrieb Ben Franksen via Tech-talk:
> Am 03.04.20 um 12:43 schrieb Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk:
>> I suspect that this may not be a simple question, but:
>> *   If I create a waveform WAVE with a soft IOC of length 10, it has
>> WAVE.NELM as 10 and WAVE.NORD as 0 *   If I caput 5 elements to it
>> (e.g. with Cothread) it has WAVE.NELM as 10 and WAVE.NORD as 5
>> Is there a way to restore it to its uninitialised state with
>> WAVE.NORD as 0? How general could this be for different record
>> types?
> The first thing I would try is:
>   caput -a WAVE 0
That gives me
Error from put operation: Invalid element count requested
Apparently this is the ECA_BADCOUNT error that comes from the CA client
library. So this is broken by design. You may have more luck with a
different CA client library (one of the Java versions?).
Cheers
Ben
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
             -- Jonathan Nitzan and Shimshon Bichler: Capital as Power
Attachment: signature.asc
Description: OpenPGP digital signature
Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Re: Setting an array to zero length Ben Franksen via Tech-talk
Prev: Re: Setting an array to zero length Ben Franksen via Tech-talk
Next: Re: Setting an array to zero length Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
