1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Setting an array to zero length
From: "Rogers, Will \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, Ben Franksen <[email protected]>
Date: Wed, 8 Apr 2020 14:13:16 +0000
This is interesting, thank you, but the intention here is to do this for an arbitrary record from a client tool over channel access.
Is the conclusion that this is not possible?
Willl
From: Tech-talk on behalf of Ben Franksen via Tech-talk
Sent: Friday, April 03, 2020 16:43
To: EPICS Tech Talk
Am 03.04.20 um 17:28 schrieb Ben Franksen via Tech-talk:
> Am 03.04.20 um 16:25 schrieb Ralph Lange via Tech-talk:
>> On Fri, 3 Apr 2020 at 15:04, Ben Franksen via Tech-talk <
>> [email protected]> wrote:
>> You could also try to use another
>>> record with NELM=NORD=0 and that has an output link that you point to
>>> your WAVE record. There is no record type in base with such an output
>>> link [...]
>> The aaoRecord since Base 3.12.2 (ca. 1995)
> Thanks I completely forgot about this one. Indeed this works:
> record(waveform, "wf") {
>     field(NELM, "10")
>     field(FTVL, "DOUBLE")
>     field(INP, [1, 2, 3, 4, 5, 6, 7, 8])
>     field(PINI, "YES")
> record(aao, "reset") {
>     field(NELM, "0")
>     field(OUT, "wf PP")
> ben@juliana[1]:.../base/7.0>caget wf
> wf 10 1 2 3 4 5 6 7 8 0 0
> ben@juliana[1]:.../base/7.0>caget wf.NORD
> wf.NORD                        8
> ben@juliana[1]:.../base/7.0>caput reset.PROC 1
> Old : reset.PROC                     0
> New : reset.PROC                     1
> wf.NORD                        0
> wf 10 2.50321e-308 0 0 0 0 0 0 0 0 0
> The last response is unexpected though. While caget -h indeed says:
> Arrays: Value format: print number of requested values, then list of values
> printing the actual number of values in the response (and only so many
> values) would be more useful. Does CA not return the current number of
> values in an array?
Ah, I see. This is a limitation of the simple ca_array_get call which is
used by default. It works as expected if I pass the -c option which
makes it use ca_array_get_callback which can return the current number
of elements.
Cheers
Ben
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
             -- Jonathan Nitzan and Shimshon Bichler: Capital as Power
Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
Prev: ci-scripts 2.2.1 available Ralph Lange via Tech-talk
Next: Re: Newport DL325 Igor Kriznar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Setting an array to zero length Ben Franksen via Tech-talk
Next: Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
