Hi John,
I see a couple of issues in your environment.
- Change QWT_INLCUDE_PATH=/nfs/opt/qwt-6.1.3.sl7/include to
QWT_INCLUDE_PATH=/nfs/opt/qwt-6.1.3.sl7/include - Change QT_PLUGIN_PATH=/nfs/chess/user/jad22/epics/qt/qeframework/lib/linux-x86_64/designer
to
On my system qt/qeframework/lib/linux-x86_64 contains libQEFramework.so
and, qt/qeframework/lib/linux-x86_64/designer
contains libQEPlugin.so
3. To test load "designer &" and scroll down the widget box in the left frame and look for the EPICSQt widgets.
Thank you also for the bug report on the Galil driver. I'll fix the issue reported in the github repository soon.
Kind regards,
Re: Galil device support - static build Ben Franksen via Tech-talk
Using CP in PV links vs. routing Hinko Kocevar via Tech-talk
<2020>
2025
2026
EPICS Puppet module v2.0 available Konrad, Martin via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
