1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Using CP in PV links vs. routing
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Hinko Kocevar <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Apr 2020 14:09:05 +0200
On 4/15/20 1:13 PM, Hinko Kocevar via Tech-talk wrote:
I have two IOCs running on the same Linux machine. I'm linking one IOC PV to the other IOC using CP in the link specification.
I'm curious of how are the PV data is routed between the two IOCs. Does it leave the machine and is routed through the network?
No. Traffic to the local IP (e.g. 192.168.0.100) is "routed"
to localhost 127.0.0.1 and will not leave the machine.
https://en.wikipedia.org/wiki/Routing_table
FWIW, the iocsh of an IOC reports that it is connecting to the PV on the NIC interface (IP), not localhost.
The kernel should do the routing, see above.
Ralph, please correct me if I'm wrong ;-)
//hinko
Using CP in PV links vs. routing Hinko Kocevar via Tech-talk
Prev: Using CP in PV links vs. routing Hinko Kocevar via Tech-talk
Next: Re: Using CP in PV links vs. routing Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
