Subject: Stream Device Format "%d" has data type signed which is not supported by RECORD
From: Peter Milne via Tech-talk <[email protected]>
To: Tech-talk <[email protected]>
Date: Mon, 27 Apr 2020 10:41:18 +0100
Hello Techtalk, especially Dirk ..
After building a new EPICS7 installation, following the useful HOWTO (Thanks!)
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation.html#install-streamdevice-by-dirk-zimoch-psi
The IOC is up and running, and mostly working on an existing large (3K) record set.
dbior "stream"
Driver: stream
  StreamDevice 2.8.12 built Apr 27 2020 10:02:57
  (C) 1999 Dirk Zimoch ([email protected])
  registered bus interfaces:
    DebugInterface
    DummyInterface
    AsynDriverInterface
But, it's not happy:
2020/04/27 09:32:24.041808 S2 acq2106_182:2:SYNC:r: Format "%d" has data type signed which is not supported by "acq2106_182:2:SYNC:r".
2020/04/27 09:32:24.042966 S0WR acq2106_182:0:WR:TS:rc: Format "%d" has data type signed which is not supported by "acq2106_182:0:WR:TS:rc".
2020/04/27 09:32:24.044793 S3 acq2106_182:3:SYNC:r: Format "%d" has data type signed which is not supported by "acq2106_182:3:SYNC:r".
2020/04/27 09:32:24.045783 S1_480 acq2106_182:1:ACQ480:TWO_LANE: Format "%d" has data type signed which is not supported by "acq2106_182:1:ACQ480:TWO_LANE".
2020/04/27 09:32:24.046208 S4_480 acq2106_182:4:ACQ480:TWO_LANE: Format "%d" has data type signed which is not supported by "acq2106_182:4:ACQ480:TWO_LANE".
.. there are hundreds of them..
The existing records are mostly mbbi. The format should write into the VAL field.
Other conversions, eg %s work OK.
Did base or StreamDevice tighten up the requirements for this?
The line of code that makes the message hasn't changed:
StreamCore.cc#1317
                            error("%s: Format \"%%%s\" has data type %s which is not supported by \"%s\".\n",
                                name(), formatstring(), StreamFormatTypeStr[fmt.type], fieldAddress ? fieldName : name());
Our previous implementation was EPICS7 base, but really just EPICS3, no EPICS4. Now we've included EPICS4 (not that that should make a difference).
Thanks
Peter
Peter Milne
Director of Sales
www.d-tacq.com
Re: Stream Device Format "%d" has data type signed which is not supported by RECORD Noboru Yamamoto via Tech-talk
Prev: Re: CA Repeater Revisited Ralph Lange via Tech-talk
Next: Adding new record to EPICS 7 IOC with pvDatabase Joao Paulo Martins via Tech-talk
Next: Re: Stream Device Format "%d" has data type signed which is not supported by RECORD Noboru Yamamoto via Tech-talk
