1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Bug report: EPICS base 7.0.3.1, deadlock
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Jonas Nilsson <[email protected]>
Date: Fri, 1 May 2020 14:08:26 -0700
On 5/1/20 3:08 AM, Jonas Nilsson via Tech-talk wrote:
> Hello,
> For lack of a better idea on where to report a bug in EPICS base, here it is;
In this case the pvAccessCPP module has both pvac::ClientProvider and the "ca" provider.
https://github.com/epics-base/pvAccessCPP
> Calling the destructor on more than one instance of a pvac::ClientProvider which has been constructed with a provider name of "ca" (channel access) causes (what appears to be) a deadlock. Using "pva" (pvAccess) does not appear to trigger this deadlock. I have attached a screenshot of where the deadlock appears to be located (from pausing the application when running it under a debugger).
Text is much preferred to screen shots.
Can you identify and provide a stack trace from the other thread(s) participating in this deadlock?
If not, please attach stack traces from all threads.
> The code that causes the triggers the deadlock can be found here: https://github.com/ess-dmsc/forward-epics-to-kafka/blob/a75fab2a7343906c147722825a258332fc2126e7/src/EpicsClient/EpicsClientMonitorImpl.h
I'm confused by the presence of both pvac::ClientProvider and the lower level epics::pvAccess::ChannelProvider.
The idea of the first is to avoid the complexities of the second.
> In this piece of code, the version of EPICS base used is 7.0.3.1. I believe I had a the same issue when testing with  earlier versions of EPICS7 a few months back as well.
> /Jonas
Bug report: EPICS base 7.0.3.1, deadlock Jonas Nilsson via Tech-talk
Prev: Re: EtherNet/IP Simulator Shen, Guobao via Tech-talk
Next: Re: EtherNet/IP Simulator Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Bug report: EPICS base 7.0.3.1, deadlock Jonas Nilsson via Tech-talk
Next: EtherNet/IP Simulator Shen, Guobao via Tech-talk
