Subject: |
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" |
Michael Davidsaver via Tech-talk <[email protected]> |
To: |
Carsten Winkler <[email protected]> |
Cc: |
[email protected] |
Date: |
Mon, 18 May 2020 09:27:02 -0700 |
libca and especially libCom can't be completely shutdown, and therefore
can't be safely unloaded.
On 5/18/20 8:34 AM, Carsten Winkler via Tech-talk wrote:
> Hi,
> for a project I need to load and unload the Channel Access context in a
> shared library. Loading is no problem but unloading. It always fails
> during ca_context_destroy() function.
> Here is my demo code:
> main.cpp (most simple case for a bigger project where it's necessary to
> load and unload different shared libraries at runtime without
> terminating main application)
> #include <windows.h>
> #include <iostream>
> int main()
> HINSTANCE hinstLib;
> BOOL fFreeResult;
> hinstLib = LoadLibrary(TEXT("myCaLib.dll"));
> if (hinstLib == NULL) {
> std::cout << "myCaLib.dll not found" << std::endl;
> return 1;
> std::cout << "library loaded; hit ENTER to unload" << std::endl;
> getchar();
> fFreeResult = FreeLibrary(hinstLib);
> std::cout << "bye" << std::endl;
> return 0;
> _______________________________________________________________________
> myCaLib.cpp (most simple shared library with no functions except
> creating and releasing the Channel Access context)
> #include <iostream>
> #include <cadef.h>
> BOOLEAN WINAPI DllMain(HINSTANCE hDllHandle, DWORD nReason, LPVOID
> Reserved) {
> switch (nReason)
> case DLL_PROCESS_ATTACH: {
> int32_t iResult =
> ca_context_create(ca_enable_preemptive_callback);
> if (iResult != ECA_NORMAL) {
> std::cout << "Error: Could not create any instance of
> Channel Access." << std::endl;
> return 0;
> std::cout << "New instance of Channel Access context." <<
> std::endl;
> std::cout << ca_context_status(ca_current_context(), 1) <<
> std::endl;
> break;
> case DLL_PROCESS_DETACH: {
> std::cout << "detach process ... " << std::endl;
> ca_context_destroy();
> break;
> return 1;
> build at command line at Windows 7 64 bit
> %comspec% /k "C:\Program Files (x86)\Microsoft Visual
> Studio\2019\Community\VC\Auxiliary\Build\vcvars64.bat"
> set base=C:\base-7.0.x <== directory of nightly build or
> stable EPICS BASE 7.0 (built with "EPICS_HOST_ARCH=windows-x64")
> cd C:\test_case\ <== directory of our test sources
> main.cpp and myCaLib.cpp
> cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
> -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -EHsc -DEPICS_BUILD_DLL
> -DEPICS_CALL_DLL -I%base%/include/compiler/msvc
> -I%base%/include/os/WIN32 -I%base%/include -c main.cpp myCaLib.cpp
> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
> -release -version:7.0 -MACHINE:X64 -libpath:%base%\lib\windows-x64
> -out:myCaLib.dll -implib:myCaLib.lib myCaLib.obj ca.lib Com.lib
> link -nologo -LTCG -incremental:no -opt:ref -release -version:7.0
> -MACHINE:X64 -out:test.exe main.obj
> set path=%base%\bin\windows-x64;%path%
> test.exe
> test.exe will freeze because it hangs on ca_context_destroy()
> I need any solution for this case, please.
> Best regards
> Carsten
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
- Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
- BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
