Some of the main benefits are:
It makes it quicker and easier to add new parameters. You add an entry in the YAML file and regenerate and it then appears as a record and as an asyn parameters so you then just add the logic referencing the new parameter.
When a parameter is added it will appear on the generated screens for all supported UIs, so facilities using different screens will see any new parameters with no effort. This would be especially nice when it is a development branch, as there is no requirement
for other sites to update the screens before they can try it out and give feedback. They just regenerate with their formatter.
An entry will also be added to a generated rst table to be displayed in the documentation.
I think it will also allow sharing of some parameters by composition rather than inheritance, such as the file parameters that are used in ADPilatus and the NDPluginFile drivers. This would simplify things for middleware services like Malcolm.
Cheers,
Gary
-- This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
