1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: anyone ever crosscompile pvaPy?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Cc: "Veseli, Sinisa" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 22 May 2020 15:27:00 +0000
Hi Peter,
On May 22, 2020, at 3:23 AM, Peter Milne via Tech-talk <[email protected]> wrote:
We have a requirement to run pvaPy on a linux-arm system.
The ARM system is configured to provide a full EPICS7, Boost lib.
Following
https://github.com/epics-base/pvaPy/blob/master/README.md
Custom Build:
Seems to build fine for EPICS_HOST_ARCH=linux-x86_64
It's also putting in hooks for linux-arm:
ls ./src/pvaccess/O.linux-arm
Makefile
But that's it, no *.o, no pvaccess.so
### eg
pgm@staffa3 pvaPy]$ make
make -C ./configure install
make -C ./pvaccess install
make[2]: Entering directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess'
pgm TOP ../.. T_A
perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-arm ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
   T_A=linux-x86_64 install
make[3]: Entering directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-x86_64'
pgm TOP ../../.. T_A linux-x86_64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DPVA_API_VERSION=482 -DPVA_RPC_API_VERSION=482 -DHAVE_BOOST_NUM_PY=0 -DHAVE_BOOST_PYTHON_NUM_PY=1 -I/usr/include -I/usr/include/python3.7m  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include        -MM -MF PyPvRecord.d  ../PyPvRecord.cpp
#### x86_64 builds all objects, but:
make[3]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-x86_64'
make -C O.linux-arm -f ../Makefile TOP=../../.. \
   T_A=linux-arm install
make[3]: Entering directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-arm'
pgm TOP ../../.. T_A linux-arm
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess/O.linux-arm'
make[2]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src/pvaccess'
make[1]: Leaving directory '/home/pgm/PROJECTS/EPICS/pvaPy/src'
.... does nothing..
Is there any way to enable a cross-compile?
I don't see any PROD_HOST entries that could be changed to PROD, for example.
The important entry in src/pvaccess/Makefile is the line
LOADABLE_LIBRARY_HOST += pvaccess
Since pvaPy is a dynamic library that gets loaded by Python, there are no binaries to create so no use of the PROD or PROD_HOST variables in the Makefile. Change the above to LOADABLE_LIBRARY and it should start cross-compiling for your target.
Hopefully you and Sinisa can work out some way to adjust the build so cross-builds like this can be configured more easily, but I suspect it may always need some kind of manual configuration to enable it.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Prev: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Next: Re: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
