1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: SoftIOC and Labview
From: "Mostafa, Jalal \(IPE\) via Tech-talk" <[email protected]>
Date: Tue, 26 May 2020 19:16:19 +0000
Hi All!
I am trying to write an array of doubles from a LabView EPICS Client using EPICS Client I/O Server to a softIoc instance with the corresponding record:
record(aai, "dummy:array")
    field(DTYP,"Soft Channel")
    field(NELM, "10")
    field(FTVL, "DOUBLE")
I can see the LabVIEW being connected to this record but no written values to softIoc instance. The issue is only happening on LabView but not when using other clients like caput for instance.
What is the correct way to write array values from LabView to softIoc records?
Best,
Jalal
Re: SoftIOC and Labview Paul Sichta via Tech-talk
Prev: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Next: Re: SoftIOC and Labview Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Mirror Control Room Konrad, Martin via Tech-talk
