1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Strange problem with areaDetector driver
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 27 May 2020 15:55:39 +0200
Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
> Hi Jörn,
> > I ran into a severe problem in the image readout handler.
> > When calling doCallbackGenericPointer() the IOC creates every time a
> > couple of  new threads and consumes lot of CPU power ( 300% on a quad
> > core).
> First a few questions:
> Is this Linux or Windows?
Linux
> What frame rate are you using?
0.5 Hz
> What plugins are running?
Only NDStdArray.
> Is the CS-Studio GUI on the same machine as the IOC or a different machine?
On the same machine
> The first thing to establish is whether the problem is the areaDetector IOC
> or the CS-Studio client.  I suggest you do the following:
> -  Disable all plugins except NDPluginStdArrays for testing.
Done,
> - Exit CS-Studio so there is no display client running.  What is the CPU
> load under those conditions?
Closed the OPI screen that shows the image. Now the number of threads is
constant. System load is at normal level.
> - Try the ImageJ viewer instead of CS-Studio for testing.  Does that also
> have the problem?
Will need some time to gat that going. Java on my system seems to have problem
with the code.
Jörn
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via
> Tech-talk <[email protected]> Sent: Wednesday, May 27, 2020 7:03 AM
> Subject: Strange problem with areaDetector driver
> Hello,
> currently I have a very strange problem in a code I'm developing to read out
> cameras from ZWO. I ran into a severe problem in the image readout handler.
> When calling doCallbackGenericPointer() the IOC creates every time a couple
> of new threads and consumes lot of CPU power ( 300% on a quad core). So
> after a very short time the system becomes unresponsive and has to be
> switched off. The image is 3520*4656 bytes in size and is in monochrome
> mode, so UInt8 as data type.
> In a GUI (CS-Studio) that is displaying the image data as Intensity graph I
> observe a "disconnect" state for every cycle of the image, once the
> NDStdArray has been enabled. In between it shows "No data".
> Has anybody seen such behavior before? Any ideas welcome how to search for
> the reason of this.
> Regards,
> Jörn Dreyer
RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Prev: Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Next: RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
