1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Update a record at a specific time
To: Donny Domagoj Cosic <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 3 Jun 2020 12:03:47 +0000
 > Additionally, a simple follow up question that I
> am not able to solve in a simple way. Is there a simple way to create a
> "if" statement without the "else" part. As in, I would like the OUT
> record processed only then the "if" condition is met.
I'm not positive I understand the question.  But if you can make your calculation "if" return 0 or non-zero then the calcout record has an OOPT field that can be either "Transition To Zero" or "Transition To Non-zero" (among other choices).  That will write the output only under the specified condition.  It also has a DOPT field that lets you write a different value from the result of the calculation if you set it to "Use OCAL" rather than "Use CAL".
From: Tech-talk <[email protected]> on behalf of Donny Domagoj Cosic via Tech-talk <[email protected]>
Sent: Wednesday, June 3, 2020 6:45 AM
To: [email protected]
Subject: Update a record at a specific time
Hello,
For archiving purposes I am trying to record a value from a PV everyday
at a specific time. I accomplished similar things using a Soft Timestamp
record when a specific date/time field updates. ie:
record(stringin, "TeslaMeters:$(position):TimeStamp"){
     field(DTYP, "Soft Timestamp")
     field(PINI, "YES")
     field(INP,  "@%d")
record(calcout, "TeslaMeters:$(position):Calc"){
    field(INPA, "TeslaMeters:$(position):TimeStamp CP")
    field(INPB, "TeslaMeters:$(position)")
    field(CALC, "B")
    field(OUT, "TeslaMeters:$(position):Midnight PP")
record(ai, "TeslaMeters:$(position):Midnight")
     field(PREC, "3")
     field(EGU,  "Tesla")
     field(PINI, "YES")
Could I use a similar strategy to compare a time string generated by the
Soft Timestamp? I see that there is a scalcout record, but i was not
able to get it to work. Additionally, a simple follow up question that I
Thank you,
Donny
Donny Domagoj Cosic
  Institut Ruder Boskovic, Bijenicka cesta 54, 10000 Zagreb, Croatia
Re: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
Prev: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
Next: Lexium MDrive Ethernet Stubbs Scott Allen (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
