1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Serious problem with base 7.0.4 on Windows
From: Hitesh Dhola via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Mon, 22 Jun 2020 15:17:59 +0530 (IST)
Dear Mark,
It also depends on the sequence of start for the IOCs. For example, If 3 iocs are started as per below sequence,
1) atest
2) btest
3) ctest
Then only "atest" is available. If you stop "atest" then IOC "btest" is getting connected automatically.
If you start IOCs in different sequence, say,
1) btest
2) ctest
3) atest
Then only IOC "btest" gets connected. If you stop "btest" IOC, "ctest" IOC is getting connected automatically.
Hitesh
From: "Mark Rivers via Tech-talk" <[email protected]>
To: "tech-talk" <[email protected]>
Sent: Saturday, June 20, 2020 2:10:55 AM
Subject: Serious problem with base 7.0.4 on Windows
Folks,
I just want to give a heads-up that I have found a serious problem in base 7.0.4 on Windows.  Running a single IOC on a computer works fine.  However, additional IOCs started on the same machine cannot be reached with Channel Access.
I assume there will be a patch release soon.  Meanwhile this patch (actually a new file) will fix the problem.
corvette:local/epics/base-7.0.4>git diff R7.0.4 modules/libcom/
diff --git a/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp b/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp
new file mode 100644
index 0000000..cc13605
--- /dev/null
+++ b/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp
@@ -0,0 +1,44 @@
+* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+*     Operator of Los Alamos National Laboratory.
+* EPICS BASE Versions 3.13.7
+* and higher are distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ * Author: Jeff Hill
+#define epicsExportSharedSymbols
+#include "osiSock.h"
+#include "errlog.h"
+ * Note: WINSOCK appears to assign a different functionality for
+ * SO_REUSEADDR compared to other OS. With WINSOCK SO_REUSEADDR indicates
+ * that simultaneously servers can bind to the same TCP port on the same host!
+ * Also, servers are always enabled to reuse a port immediately after
+ * they exit ( even if SO_REUSEADDR isnt set ).
+LIBCOM_API void epicsStdCall
+    epicsSocketEnableAddressReuseDuringTimeWaitState ( SOCKET s )
+    epicsSocketEnableAddressUseForDatagramFanout ( SOCKET s )
+    int yes = true;
+    int status;
+    status = setsockopt ( s, SOL_SOCKET, SO_REUSEADDR,
+        (char *) & yes, sizeof ( yes ) );
+    if ( status < 0 ) {
+        errlogPrintf (
+            "epicsSocketEnablePortUseForDatagramFanout: "
+            "unable to set SO_REUSEADDR?\n");
Serious problem with base 7.0.4 on Windows Mark Rivers via Tech-talk
Prev: Re: Serious problem with base 7.0.4 on Windows Michael Davidsaver via Tech-talk
Next: Re: SRQ over VXI Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
