Subject: |
Re: Does IOC name have any restrictions ? |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Tue, 23 Jun 2020 14:43:34 +0200 |
Hi Hitesh,
The standard application templates in EPICS Base use the IOC name (from the makeBaseApp command line) as the first part of a function name for some generated C code. That's why - if you use the application templates from Base - the IOC name must work as a C identifier. If you go in and manually change those names to something else that is unique on the IOC, you're fine. (In the standard structure, the IOC name is also used as part of a directory name - that would be the next place where using special characters might backfire.)
Cheers, ~Ralph
Hello,
I am getting a make error in ioc generation using makeBaseApp, if I use any numeric in name "test".
I created IOC using this,
../bin/windows-x64-mingw/makeBaseApp.pl -t ioc 3test
../bin/windows-x64-mingw/makeBaseApp.pl -i -t ioc 3test
But, make fails with following error.
---------------- 3test_registerRecordDeviceDriver.cpp:248:5: error: expected unqualified-id before numeric constant 248 | int 3test_registerRecordDeviceDriver(DBBASE *pbase) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 3test_registerRecordDeviceDriver.cpp: In function 'void rrddCallFunc(const iocshArgBuf*)': 3test_registerRecordDeviceDriver.cpp:291:19: error: unable to find numeric literal operator 'operator""test_registerRecordDeviceDriver' 291 | iocshSetError(3test_registerRecordDeviceDriver(*iocshPpdbbase)); -------------------------
It works fine if i use non-numeric, say using 'rtest' instead of '3test' is working fine. I am working on Windows 10 and MSYS environment.
Do we have any restriction in naming convention for IOC? or this is something else ? Regards, Hitesh
- Re: Does IOC name have any restrictions ? Hitesh Dhola via Tech-talk
- Does IOC name have any restrictions ? Hitesh Dhola via Tech-talk
PyQt5, QImage, and PVRecords Marty Kraimer via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
