You might try:
> # define WIN32_LEAN_AND_MEAN
> # include <windows.h>
I've never been certain what all WIN32_LEAN_AND_MEAN excludes,
but it's never been anything I was interested in.
On 6/25/20 3:47 PM, Mark Rivers via Tech-talk wrote:
> Hi Freddie and Peter,
> I am having a Windows build problem I hope you can help me with.
> I am working on the TomoPy project which involves tomography reconstruction in Python. Recently I built tomopy from source, which required me to update my Visual Studio 2017 Community installation because it wanted this version of the runtime.
> C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023
> That worked fine, and I was able to build TomoPy with Visual Studio 2017.
> However, now I am having problems with Visual Studio 2015 on the same machine. I can build EPICS base fine. However, when I try to build a program of my own that uses the EPICS build system but not EPICS functions in this file I get the following error:
> cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -MT -DEPICS_BUILD_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include -c ../grid.cpp
> grid.cpp
> c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2143: syntax error: missing ')' before 'constant'
> c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2143: syntax error: missing ';' before 'constant'
> c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2059: syntax error: 'constant'
> c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2059: syntax error: ')'
> c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2238: unexpected token(s) preceding ';'
> ../grid.cpp(120): warning C4244: '=': conversion from 'float' to 'long', possible loss of data
> The code that is being compiled when it fails is this:
> #ifdef _WIN32
> #include <windows.h>
> static LARGE_INTEGER countsPerSecond;
> static double getCurrentTime() {
> LARGE_INTEGER count;
> if (countsPerSecond.QuadPart == 0) QueryPerformanceFrequency(&countsPerSecond);
> QueryPerformanceCounter(&count);
> return double(count.QuadPart)/countsPerSecond.QuadPart;
> It is the include <windows.h> that is causing the problem. If I remove it I get different problems because Windows functions are undefined.
> The directory with the file causing the problems is c:\program files (x86)\windows kits\10\include\10.0.17763.0. That dates from June 22, 2020, which is when I updated Visual Studio 2017.
> Any idea how I can fix this?
> Thanks,
> Mark
- Windows build problem Mark Rivers via Tech-talk
RE: Windows build problem Heesterman, Peter J via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
