Subject: Re: [PV Access] Decimation Channel filter equivalent for PV Access?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Juan F. Esteban Müller <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 1 Jul 2020 16:13:09 +0000
Was that a typo in your email or were you really asking pvmonitor for n:1 and not n:2?
- Andrew
On Jul 1, 2020, at 11:09 AM, Juan F. Esteban Müller via Tech-talk <[email protected]> wrote:
Hi Michael,
Thanks for your reply.
I was suspicious, because I had the feeling I used it in the past... Can you maybe then give me a clue why I can't make it work in a simple example?
This is my db file:
record(calc, "Test:counter") {
   field(INPA, " Test:counter")
   field(CALC, "A+1")
   field(SCAN, "1 second")
And I run it using softIocPVA.
If I do
camonitor 'Test:counter.{"dec":{"n":2}}'
I get every second update, while if I do
pvmonitor 'Test:counter.{"dec":{"n":2}}'
I get nothing. Funny enough, if I do
pvmonitor 'Test:counter.{"dec":{"n":1}}'
then I get every update...
I am using base 7.0.4, but I also tested 7.0.3.1, which is the one I used in the past when testing the filters.
Cheers,
Juan
On 2020-07-01, 15:39, "Michael Davidsaver" <[email protected]> wrote:
   On 7/1/20 2:59 AM, Juan F. Esteban Müller via Tech-talk wrote:
Hi all,
I would like to know if there is anything equivalent to the CA decimation filter in PV access.
https://epics.anl.gov/base/R7-0/4-docs/filters.html#Decimation-Filter-dec
   These filters are implemented at the database level, and so work both with CA and PVA
   (via. the RSRV and QSRV server implementations).
Complexity comes for free, simplicity you have to work for.
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
Prev: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Next: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
