I have four options, and mbbo did the trick. May I assume, that this is the intended way to implement such options (At least up to 16)? From: "Jemian, Pete R." <[email protected]> To: "tech-talk" <[email protected]>, "Patrick Nonn" <[email protected]> Sent: Monday, 6 July, 2020 15:23:31 Subject: Re: Masking values in combo boxes
How many options do you have? The mbbo record does this for up to 16 choices.
From: Tech-talk <[email protected]> on behalf of Nonn, Patrick via Tech-talk <[email protected]>
Sent: Monday, July 6, 2020 8:16:19 AM To: [email protected] <[email protected]> Subject: Masking values in combo boxes Hi,
I have a longout PV, which sets the behaviour of my underlying server. The options are codified as integers. Now I would like to have a combo box with strings to "mask" the numeric values in cs studio phoebus. Should this rather be implemented in the widget or should this be implemented in the EPICS server, and if the letter, how could it be done? Regards, Patrick
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
