> I have a Combobox with items: "Ch1", "Ch2", "Ch3, "Ch4". I'd like to
> assign an action that will open another CSS panel with a macro, specific
> to each item, e.g. CH="Ch1" for item1, CH="Ch2" for item2, etc.
It describes how to use a text field to enter some PV name or part of a PV name, which is then used to set the macro for an embedded display.
Similarly, you could use a combo to set a text, then use that text to construct macro values for an embedded display.
Instead of setting the macro values on an embedded display, you could use ScriptUtil.openDisplay to, well, open a display.
-Kay
- Assign actions to Combobox items in Phoebus Peter Leban via Tech-talk
RE: RE: SteamDevice 2.8.x build on Windows issue Freddie Akeroyd - UKRI STFC via Tech-talk
RE: RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
<2020>
2025
2026
Network interruptions possible this week Johnson, Andrew N. via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
