1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: database method to copy string to char waveform
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 22 Jul 2020 16:19:46 +0200
Hi Malte,
Using current 3.15 or EPICS 7, this database:
record (waveform, "wf") {
  field(NELM, "100")
  field(FTVL, "CHAR")
  field(INP, "so.VAL$")
record (stringout, "so") {
  field(VAL, "this is a string")
does that job for me. Or did I get the problem wrong?
Cheers,
~Ralph
Re: database method to copy string to char waveform Johnson, Andrew N. via Tech-talk
database method to copy string to char waveform Malte Gotz via Tech-talk
Prev: database method to copy string to char waveform Malte Gotz via Tech-talk
Next: Re: database method to copy string to char waveform Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
