Subject: Re: How to check IOC connection
To: Mark Rivers <[email protected]>, Jong Woo Kim <[email protected]>, John Dobbins <[email protected]>
Date: Fri, 24 Jul 2020 11:20:25 +0000
Hi Jong Woo,
Are you able to ping that camera IP from the computer where you use 'camonitor' / medm? Can you use other software (i.e. Vimba) to see the camera? The two lines below seem confusing:
epicsEnvSet("CAMERA_ID","19.119.2.17")
ADVimbaConfig("VMB1", 10.139.1.11,0,0,0)
Also, you probably should use double quotation marks, i.e. "10.139.1.11" in ADVimbaConfig although it probably does not matter in your case.
Good luck!
Yong
On 7/23/20, 12:26 PM, "Tech-talk on behalf of Mark Rivers via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    > You may need to set EPICS_CA_MAX_ARRAY_BYTES on server and client.
    I don't think that is the current problem.  That will only prevent receiving large arrays (images), but PVs should connect.  I think the problem is most likely a firewall.
    It could also be an incorrect setting of EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST.  Check to make sure those environment variables are not defined, or if they are defined that they are correct.
    From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
    Sent: Thursday, July 23, 2020 11:20 AM
    To: [email protected]; Jong Woo Kim
    Jong Woo,
    John Dobbins
    From: Tech-talk <[email protected]> on behalf of Jong Woo Kim via Tech-talk <[email protected]>
    Sent: Thursday, July 23, 2020 12:16 PM
    To: [email protected] <[email protected]>
    Subject: How to check IOC connection
    Dear All,
    I connected IOC for camera without error. But I cannot see any PVs with 'camonitor' neither with medm.
    Could you let me know what's wrong?
    ____________________________________________________________________________
    [jkim@localhost iocVimba]$ ../../bin/linux-x86_64/vimbaApp st.cmd
    < envPaths
    epicsEnvSet("IOC","iocVimba")
    epicsEnvSet("TOP","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC")
    epicsEnvSet("ADVIMBA","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../..")
    epicsEnvSet("SUPPORT","/usr/local/EPICS_NEW/synApps_6_1/support")
    epicsEnvSet("ASYN","/usr/local/EPICS_NEW/synApps_6_1/support/asyn4-38")
    epicsEnvSet("AREA_DETECTOR","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector")
    epicsEnvSet("ADSUPPORT","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADSupport")
    epicsEnvSet("ADCORE","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore")
    epicsEnvSet("AUTOSAVE","/usr/local/EPICS_NEW/synApps_6_1/support/autosave-R5-10")
    epicsEnvSet("BUSY","/usr/local/EPICS_NEW/synApps_6_1/support/busy-R1-7-2")
    epicsEnvSet("CALC","/usr/local/EPICS_NEW/synApps_6_1/support/calc-R3-7-3")
    epicsEnvSet("SNCSEQ","/usr/local/EPICS_NEW/synApps_6_1/support/seq-2-2-6")
    epicsEnvSet("SSCAN","/usr/local/EPICS_NEW/synApps_6_1/support/sscan-R2-11-3")
    epicsEnvSet("DEVIOCSTATS","/usr/local/EPICS_NEW/synApps_6_1/support/iocStats-3-1-16")
    epicsEnvSet("ALIVE","/usr/local/EPICS_NEW/synApps_6_1/support/alive-R1-1-1")
    epicsEnvSet("EPICS_BASE","/usr/local/EPICS_NEW/base-3.15.6")
    epicsEnvSet("ADGENICAM","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam")
    errlogInit(20000)
    dbLoadDatabase("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/dbd/vimbaApp.dbd")
    vimbaApp_registerRecordDeviceDriver(pdbbase)
    # Location of transport layer definition files
    epicsEnvSet("GENICAM_GENTL64_PATH", "/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../bin/linux-x86_64")
    epicsEnvSet("GENICAM_DB_FILE", "/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/db/AVT_Mako_G507B.template")
    # Prefix for all records
    epicsEnvSet("PREFIX","13VMB1:")
    epicsEnvSet("MODULE","cam1:")
    # The port name for the detector
    epicsEnvSet("PORT",   "VMB1")
    # Really large queue so we can stream to disk at full camera speed
    epicsEnvSet("QSIZE",  "2000000")
    # The maximim image width; used for row profiles in the NDPluginStats plugin
    epicsEnvSet("XSIZE",  "2464")
    # The maximim image height; used for column profiles in the NDPluginStats plugin
    epicsEnvSet("YSIZE",  "2056")
    # The maximum number of time series points in the NDPluginStats plugin
    epicsEnvSet("NCHANS", "2048")
    # The maximum number of frames buffered in the NDPluginCircularBuff plugin
    epicsEnvSet("CBUFFS", "500")
    # The search path for database files
    epicsEnvSet("EPICS_DB_INCLUDE_PATH","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db:/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/db:/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../db")
    # Define NELEMENTS to be enough for a 2048x2048x3 (color) image
    epicsEnvSet("NELEMENTS","15197952")
    # ADVimbaConfig(const char *portName, const char *cameraId,
    #                   size_t maxMemory, int priority, int stackSize)
    asynSetTraceIOMask(VMB1, 0, 2)
    # Set ASYN_TRACE_WARNING and ASYN_TRACE_ERROR
    #asynSetTraceMask($(PORT), 0, 0xff)
    #asynSetTraceFile($(PORT), 0, "asynTrace.out")
    #asynSetTraceInfoMask($(PORT), 0, 0xf)
    # Main database
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../db/vimba.template", "P=13VMB1:,R=cam1:, PORT=VMB1")
    # Load the autogenerated file of GenICam features
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/db/AVT_Mako_G507B.template", "P=13VMB1:,R=cam1:, PORT=VMB1")
    # Create a standard arrays plugin
    NDStdArraysConfigure("Image1", 5, 0, "VMB1", 0, 0)
    # Use this line for 8-bit data only
    #dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=CHAR,NELEMENTS=$(NELEMENTS)")
    # Use this line for 8-bit or 16-bit data
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDStdArrays.template", "P=13VMB1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1,TYPE=Int16,FTVL=SHORT,NELEMENTS=15197952")
    # Load all other plugins using commonPlugins.cmd
    < /usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/iocBoot/commonPlugins.cmd
    # This is an example file for creating plugins
    # It uses the following environment variable macros
    # Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
    # use the autosave value will replace the value passed to this file.
    # $(PREFIX)      Prefix for all records
    # $(PORT)        The port name for the detector.  In autosave.
    # $(QSIZE)       The queue size for all plugins.  In autosave.
    # $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
    #                   profiles in NDPluginFFT.
    # $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
    # $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
    # $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
    # $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
    # Create a netCDF file saving plugin
    NDFileNetCDFConfigure("FileNetCDF1", 2000000, 0, "VMB1", 0)
    dbLoadRecords("NDFileNetCDF.template","P=13VMB1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a TIFF file saving plugin
    NDFileTIFFConfigure("FileTIFF1", 2000000, 0, "VMB1", 0)
    dbLoadRecords("NDFileTIFF.template",  "P=13VMB1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a JPEG file saving plugin
    NDFileJPEGConfigure("FileJPEG1", 2000000, 0, "VMB1", 0)
    dbLoadRecords("NDFileJPEG.template",  "P=13VMB1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a NeXus file saving plugin
    NDFileNexusConfigure("FileNexus1", 2000000, 0, "VMB1", 0)
    dbLoadRecords("NDFileNexus.template", "P=13VMB1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create an HDF5 file saving plugin
    NDFileHDF5Configure("FileHDF1", 2000000, 0, "VMB1", 0)
    dbLoadRecords("NDFileHDF5.template",  "P=13VMB1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=VMB1")
    # Create a Magick file saving plugin
    #NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
    #dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
    # Create 4 ROI plugins
    NDROIConfigure("ROI1", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDROI.template",       "P=13VMB1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    NDROIConfigure("ROI2", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDROI.template",       "P=13VMB1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    NDROIConfigure("ROI3", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDROI.template",       "P=13VMB1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    NDROIConfigure("ROI4", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDROI.template",       "P=13VMB1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create 8 ROIStat plugins
    NDROIStatConfigure("ROISTAT1", 2000000, 0, "VMB1", 0, 8, 0, 0, 0, 0, 5)
    dbLoadRecords("NDROIStat.template",   "P=13VMB1:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDROIStatN.template",  "P=13VMB1:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
    # Create a processing plugin
    NDProcessConfigure("PROC1", 2000000, 0, "VMB1", 0, 0, 0)
    dbLoadRecords("NDProcess.template",   "P=13VMB1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a TIFF file plugin to read dark and flatfield images into the processing plugin
    NDFileTIFFConfigure("PROC1TIFF", 2000000, 0, "VMB1", 0)
    dbLoadRecords("NDFileTIFF.template",  "P=13VMB1:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a scatter plugin
    NDScatterConfigure("SCATTER1", 2000000, 0, "VMB1", 0, 0, 0)
    dbLoadRecords("NDScatter.template",   "P=13VMB1:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a gather plugin with 8 ports
    NDGatherConfigure("GATHER1", 2000000, 0, 8, 0, 0)
    dbLoadRecords("NDGather.template",   "P=13VMB1:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDGatherN.template",   "P=13VMB1:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create 5 statistics plugins
    NDStatsConfigure("STATS1", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDStats.template",     "P=13VMB1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2464,YSIZE=2056,NCHANS=2048,NDARRAY_PORT=VMB1")
    NDTimeSeriesConfigure("STATS1_TS", 2000000, 0, "STATS1", 1, 23)
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=13VMB1:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
    NDStatsConfigure("STATS2", 2000000, 0, "ROI1",    0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDStats.template",     "P=13VMB1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2464,YSIZE=2056,NCHANS=2048,NDARRAY_PORT=VMB1")
    NDTimeSeriesConfigure("STATS2_TS", 2000000, 0, "STATS2", 1, 23)
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=13VMB1:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
    NDStatsConfigure("STATS3", 2000000, 0, "ROI2",    0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDStats.template",     "P=13VMB1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2464,YSIZE=2056,NCHANS=2048,NDARRAY_PORT=VMB1")
    NDTimeSeriesConfigure("STATS3_TS", 2000000, 0, "STATS3", 1, 23)
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=13VMB1:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
    NDStatsConfigure("STATS4", 2000000, 0, "ROI3",    0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDStats.template",     "P=13VMB1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2464,YSIZE=2056,NCHANS=2048,NDARRAY_PORT=VMB1")
    NDTimeSeriesConfigure("STATS4_TS", 2000000, 0, "STATS4", 1, 23)
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=13VMB1:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
    NDStatsConfigure("STATS5", 2000000, 0, "ROI4",    0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDStats.template",     "P=13VMB1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2464,YSIZE=2056,NCHANS=2048,NDARRAY_PORT=VMB1")
    NDTimeSeriesConfigure("STATS5_TS", 2000000, 0, "STATS5", 1, 23)
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=13VMB1:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
    # Create a transform plugin
    NDTransformConfigure("TRANS1", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDTransform.template", "P=13VMB1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create an overlay plugin with 8 overlays
    NDOverlayConfigure("OVER1", 2000000, 0, "VMB1", 0, 8, 0, 0, 0, 0, 5)
    dbLoadRecords("NDOverlay.template", "P=13VMB1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=13VMB1:ROI1:MinX_RBV,YPOS=13VMB1:ROI1:MinY_RBV,XSIZE=13VMB1:ROI1:SizeX_RBV,YSIZE=13VMB1:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=13VMB1:ROI2:MinX_RBV,YPOS=13VMB1:ROI2:MinY_RBV,XSIZE=13VMB1:ROI2:SizeX_RBV,YSIZE=13VMB1:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=13VMB1:ROI3:MinX_RBV,YPOS=13VMB1:ROI3:MinY_RBV,XSIZE=13VMB1:ROI3:SizeX_RBV,YSIZE=13VMB1:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=13VMB1:ROI4:MinX_RBV,YPOS=13VMB1:ROI4:MinY_RBV,XSIZE=13VMB1:ROI4:SizeX_RBV,YSIZE=13VMB1:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
    dbLoadRecords("NDOverlayN.template","P=13VMB1:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
    # Create 2 color conversion plugins
    NDColorConvertConfigure("CC1", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDColorConvert.template", "P=13VMB1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    NDColorConvertConfigure("CC2", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDColorConvert.template", "P=13VMB1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create a circular buffer plugin
    NDCircularBuffConfigure("CB1", 2000000, 0, "VMB1", 0, 500, 0)
    dbLoadRecords("NDCircularBuff.template", "P=13VMB1:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=VMB1")
    # Create an NDAttribute plugin with 8 attributes
    NDAttrConfigure("ATTR1", 2000000, 0, "VMB1", 0, 8, 0, 0, 0)
    dbLoadRecords("NDAttribute.template",  "P=13VMB1:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=VMB1")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
    dbLoadRecords("NDAttributeN.template", "P=13VMB1:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
    NDTimeSeriesConfigure("ATTR1_TS", 2000000, 0, "ATTR1", 1, 8)
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=13VMB1:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
    # Create an FFT plugin
    NDFFTConfigure("FFT1", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDFFT.template", "P=13VMB1:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1, NAME=FFT1, NCHANS=2464")
    # Create 2 Codec plugins
    NDCodecConfigure("CODEC1", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDCodec.template", "P=13VMB1:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1")
    NDCodecConfigure("CODEC2", 2000000, 0, "VMB1", 0, 0, 0, 0, 0, 5)
    dbLoadRecords("NDCodec.template", "P=13VMB1:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=VMB1")
    set_requestfile_path("./")
    set_requestfile_path("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/ADApp/Db")
    set_requestfile_path("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/iocBoot")
    set_savefile_path("./autosave")
    set_pass0_restoreFile("auto_settings.sav")
    set_pass1_restoreFile("auto_settings.sav")
    save_restoreSet_status_prefix("13VMB1:")
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/autosave-R5-10/asApp/Db/save_restoreStatus.db", "P=13VMB1:")
    # Optional: load NDPluginPva plugin
    #NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0)
    #dbLoadRecords("NDPva.template",  "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
    # Must start PVA server if this is enabled
    #startPVAServer
    # Optional: load ffmpegServer plugin
    #ffmpegServerConfigure(8081)
    #ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0)
    #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)")
    #ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0)
    #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)")
    # Optional: load NDPluginEdge plugin
    #NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
    #dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
    #set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db")
    # Optional: load NDPluginCV plugin
    #NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
    #dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template",  "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
    #set_requestfile_path("$(ADCOMPVISION)/adcvApp/Db")
    # Optional: load NDPluginBar plugin
    #NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
    #dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template",  "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
    #set_requestfile_path("$(ADPLUGINBAR)/barApp/Db")
    # Optional: load scan records
    #dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
    #set_requestfile_path("$(SSCAN)/sscanApp/Db")
    # Optional: load sseq record for acquisition sequence
    dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/calc-R3-7-3/calcApp/Db/sseqRecord.db", "P=13VMB1:, S=AcquireSequence")
    set_requestfile_path("/usr/local/EPICS_NEW/synApps_6_1/support/calc-R3-7-3/calcApp/Db")
    # Optional: load devIocStats records (requires DEVIOCSTATS module)
    #dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")
    # Optional: load alive record (requires ALIVE module)
    #dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
    # Set the callback queue size to 5000, up from default of 2000 in base.
    # This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
    callbackSetQueueSize(5000)
    set_requestfile_path("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/GenICamApp/Db")
    set_requestfile_path("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../vimbaApp/Db")
    iocInit()
    Starting iocInit
    ## EPICS R3.15.6
    ## EPICS Base built Jul 14 2020
    reboot_restore: entry for file 'auto_settings.sav'
    reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
    *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
    save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200723-120837'
    save_restore: Can't write backup file.
    *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
    reboot_restore: done with file 'auto_settings.sav'
    # save things every thirty seconds
    create_monitor_set("auto_settings.req", 30,"P=13VMB1:")
    # Wait for enum callbacks to complete
    epicsThreadSleep(1.0)
    auto_settings.sav: 2287 of 2287 PV's connected
    # Wait for callbacks on the property limits (DRVL, DRVH) to complete
    epics>
    Best,
    Jong Woo
Re: How to check IOC connection Jong Woo Kim via Tech-talk
Re: How to check IOC connection John Dobbins via Tech-talk
Re: How to check IOC connection Mark Rivers via Tech-talk
Prev: Re: Adding a PV to archiver appl, missing something... Hu, Yong via Tech-talk
Next: RE: ADProsilica crashing on RHEL7 3.10.0-1127 Mark Rivers via Tech-talk
Prev: Re: How to check IOC connection Mark Rivers via Tech-talk
Next: Re: How to check IOC connection Jong Woo Kim via Tech-talk
