1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: edm logging
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Sun, 2 Aug 2020 16:04:06 +0200
On Sun, 2 Aug 2020 at 05:23, Silver via Tech-talk <[email protected]> wrote:
In the edm help document, it says specified PVs operations can be logged. For example, if I want to log PV1 named as "test:ai1", not log PV2 named as "test:ai2", how to edit edmPvObjects file?
ps, if I set EDMpUTLOGGER=cat, the tty out put messages as follows :
user="sinclair" host="edmhost" dsp=":0.0" name="sinclairHost:ao0"...... old="0.000000" new="1.000000"
can I add the time information in a simple way?
thanks a lot for your help.
Please also have a look at the caPutLog module: https://github.com/epics-modules/caPutLog
It hooks into the Access Security layer and does such kind of tracking and logging on the server (IOC) side, which - depending on your exact use case - might be a more appropriate solution.
Cheers,
~Ralph
edm logging Silver via Tech-talk
Prev: edm logging Silver via Tech-talk
Next: EPICS Qt 3.7.4 available [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
