Subject: Re: [EXTERNAL] Phoebus X-Y Graph
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Florian Feldbauer <[email protected]>
Date: Wed, 12 Aug 2020 14:37:02 +0000
Hi:
When combining a scalar 'X' and 'Y' reading into a time series, there are several options:
a) Have 'Y' update trigger a data point, using the then-current value of X
b) Have 'X' update ... of Y
c) Have a third 'Trigger' PV
d) Pick values where the time stamp matches with 0.01 seconds
e) Do something entirely different
The x-y-graph widget in Phoebus doesn't try to implement any of the above.
It simply displays two waveforms into which you collected the data as you see fit.
For example, you could use an IOC database with 'compress' records in 'circular buffer' mode to collect the data into waveforms.
Kay
From: Tech-talk <[email protected]> on behalf of Florian Feldbauer via Tech-talk <[email protected]>
Sent: Wednesday, August 12, 2020 10:25 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Phoebus X-Y Graph
Hey all,
we need to test some pixel sensors, and one check is measuring the
current for different bias voltage settings.
Can I use the x-y-graph widget in Phoebus to display the current vs voltage?
Is it just showing only the actual value or does it also have a sort of
history like the databrowser?
Best regards,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: [EXTERNAL] Phoebus X-Y Graph Florian Feldbauer via Tech-talk
Prev: Phoebus X-Y Graph Florian Feldbauer via Tech-talk
Next: New Focus 8753 John Dobbins via Tech-talk
Next: Re: [EXTERNAL] Phoebus X-Y Graph Florian Feldbauer via Tech-talk
