1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
To: "'Gofron, Kazimierz'" <[email protected]>
Date: Thu, 13 Aug 2020 21:33:30 +0000
Hi Kaz,
Ø  Camera Manta G-125B
Ø  S/N: xxxxx
Ø  Firmware: 00.01.44.18241
Ø  SDK: 1.26
Ø  Driver: 2.5.0
Ø  ADCore: 3.5.0
None of that should matter.
Ø  kgofron@xf10id-ws1:~$ export EPICS_CA_MAX_ARRAY_BYTES=6000000
That is not relevant to pvAccess.
Ø  Aug 13, 2020 4:59:34 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
Ø  SEVERE: Failed to create transport for: /10.10.0.2:48464
Ø  org.epics.pvaccess.impl.remote.ConnectionException: Failed to connect to '/10.10.0.2:48464'.
Ø  SEVERE: Failed to create transport for: /10.10.1.3:48464
Ø  org.epics.pvaccess.impl.remote.ConnectionException: Failed to connect to '/10.10.1.3:48464'.
I have never seen errors like those, so I don’t know what could be wrong.
Ø  My EPICS VLAN interfaces are on 10.10.0.x, and interfaces 10.10.1.y are for direct access to webcams.
What is at IP addresses 10.10.0.2 and 10.10.1.3?
From: Tech-talk <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Thursday, August 13, 2020 4:17 PM
To: [email protected]
Subject: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
Camera Manta G-125B
S/N: xxxxx
SDK: 1.26
Driver: 2.5.0
ADCore: 3.5.0
OS (client where imagej is running): Debian 10
OS (EPICS ioc server): Debian 7
imagej debian version:
kgofron@xf10id-ws1:~$ dpkg -l | grep imagej
ii  imagej                                        1.52j-1                                      all          Image processing program with a focus on microscopy images
I just cloned the master version of imagej viewers, and 'EPICS_AD Viewer' CA version works fine, but the 'EPICS_NTNDA_VIEWER' PVA version does not connect. Am I missing something?
In the same time CSS opi displays PvA images correctly.
kgofron@xf10id-ws1:~$ imagej
Open other images in this ImageJ panel as follows:
  imagej -p 1 <image1> [<image2> ... <imageN>]
at org.epics.pvaccess.client.impl.remote.tcp.BlockingTCPConnector.connect(BlockingTCPConnector.java:163)
at org.epics.pvaccess.client.impl.remote.ClientContextImpl.getTransport(ClientContextImpl.java:1125)
at org.epics.pvaccess.client.impl.remote.ChannelImpl.searchResponse(ChannelImpl.java:453)
at org.epics.pvaccess.client.impl.remote.search.SimpleChannelSearchManagerImpl.searchResponse(SimpleChannelSearchManagerImpl.java:384)
at org.epics.pvaccess.client.impl.remote.handlers.SearchResponseHandler.handleResponse(SearchResponseHandler.java:94)
at org.epics.pvaccess.client.impl.remote.ClientResponseHandler.handleResponse(ClientResponseHandler.java:108)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport.processBuffer(BlockingUDPTransport.java:336)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport.processRead(BlockingUDPTransport.java:263)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport$1.run(BlockingUDPTransport.java:159)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.NoClassDefFoundError: org/omg/CORBA/ShortHolder
at org.epics.pvaccess.impl.remote.IntrospectionRegistry.<init>(IntrospectionRegistry.java:77)
at org.epics.pvaccess.impl.remote.tcp.BlockingTCPTransport.<init>(BlockingTCPTransport.java:64)
at org.epics.pvaccess.client.impl.remote.tcp.BlockingClientTCPTransport.<init>(BlockingClientTCPTransport.java:96)
at org.epics.pvaccess.client.impl.remote.ClientContextImpl$1.create(ClientContextImpl.java:417)
at org.epics.pvaccess.client.impl.remote.tcp.BlockingTCPConnector.connect(BlockingTCPConnector.java:137)
... 9 more
Caused by: java.lang.ClassNotFoundException: org.omg.CORBA.ShortHolder
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:589)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 14 more
... 9 more
Aug 13, 2020 4:59:35 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
... 9 more
... 9 more
Aug 13, 2020 4:59:36 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:38 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:39 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:42 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:49 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:50 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
Aug 13, 2020 4:59:51 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Prev: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
