Subject: Re: Question about static linking in the EPICS build system
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "Johnson, Andrew N." <[email protected]>, "Wlodek, Jakub" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 17 Aug 2020 18:02:57 +0000
Hi all,
I was able to solve the issue. I searched through the CMake logs and it seems that there are two different versions of libusb,
libusb by itself, and libusb-1.0. I am not sure what is different about these two, but it seems libuvc links against libusb-1.0
by default, and I was trying to link libusb, which was causing the issue.
Using Mark's suggestion, adding the following to the IOC Makefile resolved the problem:
 $(PROD_NAME)_SYS_LIBS += usb-1.0
Thanks again for the assistance,
Jakub
From: Tech-talk <[email protected]> on behalf of Wlodek, Jakub via Tech-talk <[email protected]>
Sent: Monday, August 17, 2020 1:51 PM
To: Mark Rivers <[email protected]>; Johnson, Andrew N. <[email protected]>
Hi Mark,
This was one of the initial things I tried before reaching out to tech talk. I added:
to the IOC makefile, and I got the same error message, and then later I tried the same but also
adding LIB_SYS_LIBS += usb in the Makefile for the driver library. Here is the full output of make - note
that the usb library is being linked seemingly at the end of the output:
jwlodek@ubuntu:/epics/src/support/areaDetector/ADUVC$ make
make -C ./configure install
make[1]: Entering directory '/epics/src/support/areaDetector/ADUVC/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/epics/src/support/areaDetector/ADUVC/configure/O.linux-x86_64'
perl -CSD /epics/src/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/epics/src/support/areaDetector/ADUVC/configure/O.linux-x86_64'
make[1]: Leaving directory '/epics/src/support/areaDetector/ADUVC/configure'
make -C ./uvcSupport install
make[1]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcSupport'
make[2]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcSupport/O.linux-x86_64'
Installing generic include file ../../include/libuvc/libuvc.h
Installing generic include file ../../include/libuvc/libuvc_config.h
Installing generic include file ../../include/libuvc/libuvc_internal.h
Installing generic include file ../../include/utlist.h
Installing libuvc.a
Installing libuvc.so
Installing libuvc.so.0
Installing libuvc.so.0.0.6
make[2]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcSupport/O.linux-x86_64'
make[1]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcSupport'
make -C ./uvcApp install
make[1]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcApp'
make -C ./src install
make[2]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -std=c++11   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/epics/src/support/asyn/include     -I/epics/src/support/areaDetector/ADSupport/include/os/Linux -I/epics/src/support/areaDetector/ADSupport/include   -I/epics/src/support/areaDetector/ADCore/include -I/epics/src/base/include/compiler/gcc -I/epics/src/base/include/os/Linux -I/epics/src/base/include        -c ../ADUVC.cpp
/usr/bin/ar -rc    libADUVC.a     ADUVC.o
/usr/bin/ranlib libADUVC.a
/usr/bin/g++ -o libADUVC.so -shared -fPIC -Wl,-hlibADUVC.so -L/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64 -L/epics/src/base/lib/linux-x86_64 -L/epics/src/support/areaDetector/ADCore/lib/linux-x86_64 -L/epics/src/support/areaDetector/ADSupport/lib/linux-x86_64 -L/epics/src/support/asyn/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64 -Wl,-rpath,/epics/src/base/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADSupport/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/asyn/lib/linux-x86_64           -rdynamic -m64          ADUVC.o   -luvc -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lusb -ljpeg -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libADUVC.so
Installing library ../../../lib/linux-x86_64/libADUVC.a
make[3]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcApp/src/O.linux-x86_64'
make[2]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcApp/src'
make -C ./Db install
make[2]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcApp/Db'
perl -CSD /epics/src/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make[3]: Entering directory '/epics/src/support/areaDetector/ADUVC/uvcApp/Db/O.linux-x86_64'
Installing template file ../../../db/ADUVC.template
mkdir ../../../db
make[3]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcApp/Db/O.linux-x86_64'
make[2]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcApp/Db'
make[1]: Leaving directory '/epics/src/support/areaDetector/ADUVC/uvcApp'
make -C ./iocs install
make[1]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs'
make -C ./uvcIOC install
make[2]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC'
make[3]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/configure'
mkdir -p O.Common
make[4]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/configure/O.linux-x86_64'
make[4]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/configure/O.linux-x86_64'
make[3]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/configure'
make[3]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/uvcApp'
make[4]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/uvcApp/src'
mkdir -p O.Common
make[5]: Entering directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/uvcApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/epics/src/support/areaDetector/ADUVC/include      -I/epics/src/support/asyn/include     -I/epics/src/support/areaDetector/ADSupport/include/os/Linux -I/epics/src/support/areaDetector/ADSupport/include   -I/epics/src/support/areaDetector/ADCore/include  -I/epics/src/support/autosave/include/os/Linux -I/epics/src/support/autosave/include   -I/epics/src/support/busy/include   -I/epics/src/support/calc/include   -I/epics/src/support/seq/include   -I/epics/src/support/sscan/include  -I/epics/src/support/iocStats/include/os/Linux -I/epics/src/support/iocStats/include -I/epics/src/base/include/compiler/gcc -I/epics/src/base/include/os/Linux -I/epics/src/base/include        -MM -MF uvcAppMain.d  ../uvcAppMain.cpp
Creating dbd file uvcApp.dbd
perl -CSD /epics/src/base/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/epics/src/support/areaDetector/ADUVC/dbd -I/epics/src/support/asyn/dbd -I/epics/src/support/areaDetector/ADCore/dbd -I/epics/src/support/autosave/dbd -I/epics/src/support/busy/dbd -I/epics/src/support/calc/dbd -I/epics/src/support/seq/dbd -I/epics/src/support/sscan/dbd -I/epics/src/support/iocStats/dbd -I/epics/src/base/dbd -o uvcApp.dbd uvcSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd qsrv.dbd NDPluginPva.dbd PVAServerRegister.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileNexus.dbd NDFileHDF5.dbd NDFileJPEG.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
perl -CSD /epics/src/base/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/epics/src/support/areaDetector/ADUVC/dbd -I/epics/src/support/asyn/dbd -I/epics/src/support/areaDetector/ADCore/dbd -I/epics/src/support/autosave/dbd -I/epics/src/support/busy/dbd -I/epics/src/support/calc/dbd -I/epics/src/support/seq/dbd -I/epics/src/support/sscan/dbd -I/epics/src/support/iocStats/dbd -I/epics/src/base/dbd    -o uvcApp_registerRecordDeviceDriver.cpp ../O.Common/uvcApp.dbd uvcApp_registerRecordDeviceDriver /epics/src/support/areaDetector/ADUVC/iocs/uvcIOC
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/epics/src/support/areaDetector/ADUVC/include      -I/epics/src/support/asyn/include     -I/epics/src/support/areaDetector/ADSupport/include/os/Linux -I/epics/src/support/areaDetector/ADSupport/include   -I/epics/src/support/areaDetector/ADCore/include  -I/epics/src/support/autosave/include/os/Linux -I/epics/src/support/autosave/include   -I/epics/src/support/busy/include   -I/epics/src/support/calc/include   -I/epics/src/support/seq/include   -I/epics/src/support/sscan/include  -I/epics/src/support/iocStats/include/os/Linux -I/epics/src/support/iocStats/include -I/epics/src/base/include/compiler/gcc -I/epics/src/base/include/os/Linux -I/epics/src/base/include        -MM -MF uvcApp_registerRecordDeviceDriver.d  uvcApp_registerRecordDeviceDriver.cpp
Installing created dbd file ../../../dbd/uvcApp.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/epics/src/support/areaDetector/ADUVC/include      -I/epics/src/support/asyn/include     -I/epics/src/support/areaDetector/ADSupport/include/os/Linux -I/epics/src/support/areaDetector/ADSupport/include   -I/epics/src/support/areaDetector/ADCore/include  -I/epics/src/support/autosave/include/os/Linux -I/epics/src/support/autosave/include   -I/epics/src/support/busy/include   -I/epics/src/support/calc/include   -I/epics/src/support/seq/include   -I/epics/src/support/sscan/include  -I/epics/src/support/iocStats/include/os/Linux -I/epics/src/support/iocStats/include -I/epics/src/base/include/compiler/gcc -I/epics/src/base/include/os/Linux -I/epics/src/base/include        -c uvcApp_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/epics/src/support/areaDetector/ADUVC/include      -I/epics/src/support/asyn/include     -I/epics/src/support/areaDetector/ADSupport/include/os/Linux -I/epics/src/support/areaDetector/ADSupport/include   -I/epics/src/support/areaDetector/ADCore/include  -I/epics/src/support/autosave/include/os/Linux -I/epics/src/support/autosave/include   -I/epics/src/support/busy/include   -I/epics/src/support/calc/include   -I/epics/src/support/seq/include   -I/epics/src/support/sscan/include  -I/epics/src/support/iocStats/include/os/Linux -I/epics/src/support/iocStats/include -I/epics/src/base/include/compiler/gcc -I/epics/src/base/include/os/Linux -I/epics/src/base/include        -c ../uvcAppMain.cpp
/usr/bin/g++ -o uvcApp -Wl,-Bstatic -L/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/lib/linux-x86_64 -L/epics/src/base/lib/linux-x86_64 -L/epics/src/support/areaDetector/ADCore/lib/linux-x86_64 -L/epics/src/support/areaDetector/ADSupport/lib/linux-x86_64 -L/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64 -L/epics/src/support/asyn/lib/linux-x86_64 -L/epics/src/support/autosave/lib/linux-x86_64 -L/epics/src/support/busy/lib/linux-x86_64 -L/epics/src/support/calc/lib/linux-x86_64 -L/epics/src/support/iocStats/lib/linux-x86_64 -L/epics/src/support/seq/lib/linux-x86_64 -L/epics/src/support/sscan/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/lib/linux-x86_64 -Wl,-rpath,/epics/src/base/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADSupport/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/asyn/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/autosave/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/busy/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/calc/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/iocStats/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/seq/lib/linux-x86_64 -Wl,-rpath,/epics/src/support/sscan/lib/linux-x86_64           -rdynamic -m64         uvcApp_registerRecordDeviceDriver.o uvcAppMain.o    -lADUVC -luvc -lNDPlugin -lADBase -lqsrv -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lusb -ljpeg -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: /epics/src/support/areaDetector/ADSupport/lib/linux-x86_64/libjp2.a(jas_stream.o): in function `jas_stream_tmpfile':
jas_stream.c:(.text+0x7e9): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o): in function `_uvc_stream_callback':
stream.c:(.text+0x674): undefined reference to `libusb_free_transfer'
/usr/bin/ld: stream.c:(.text+0x6ba): undefined reference to `libusb_submit_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o): in function `uvc_query_stream_ctrl':
stream.c:(.text+0x902): undefined reference to `libusb_control_transfer'
/usr/bin/ld: stream.c:(.text+0x9e2): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o): in function `uvc_query_still_ctrl':
stream.c:(.text+0xb05): undefined reference to `libusb_control_transfer'
/usr/bin/ld: stream.c:(.text+0xb81): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o): in function `uvc_trigger_still':
stream.c:(.text+0xc36): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o):stream.c:(.text+0xd24): more undefined references to `libusb_control_transfer' follow
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o): in function `uvc_stream_start':
stream.c:(.text+0x1e00): undefined reference to `libusb_get_ss_endpoint_companion_descriptor'
/usr/bin/ld: stream.c:(.text+0x1e13): undefined reference to `libusb_free_ss_endpoint_companion_descriptor'
/usr/bin/ld: stream.c:(.text+0x1e76): undefined reference to `libusb_set_interface_alt_setting'
/usr/bin/ld: stream.c:(.text+0x1edb): undefined reference to `libusb_alloc_transfer'
/usr/bin/ld: stream.c:(.text+0x1fcb): undefined reference to `libusb_submit_transfer'
/usr/bin/ld: stream.c:(.text+0x2016): undefined reference to `libusb_free_transfer'
/usr/bin/ld: stream.c:(.text+0x2307): undefined reference to `libusb_alloc_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(stream.c.o): in function `uvc_stream_stop':
stream.c:(.text+0x28e1): undefined reference to `libusb_cancel_transfer'
/usr/bin/ld: stream.c:(.text+0x28fe): undefined reference to `libusb_free_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): in function `uvc_get_scanning_mode':
ctrl-gen.c:(.text+0x5f): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): in function `uvc_set_scanning_mode':
ctrl-gen.c:(.text+0xfe): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): in function `uvc_get_ae_mode':
ctrl-gen.c:(.text+0x18f): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): in function `uvc_set_ae_mode':
ctrl-gen.c:(.text+0x22e): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): in function `uvc_get_ae_priority':
ctrl-gen.c:(.text+0x2bf): undefined reference to `libusb_control_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o):ctrl-gen.c:(.text+0x35e): more undefined references to `libusb_control_transfer' follow
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_free_device_info':
device.c:(.text+0x517): undefined reference to `libusb_free_config_descriptor'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_get_device_descriptor':
device.c:(.text+0x650): undefined reference to `libusb_get_device_descriptor'
/usr/bin/ld: device.c:(.text+0x6a4): undefined reference to `libusb_open'
/usr/bin/ld: device.c:(.text+0x6d0): undefined reference to `libusb_get_string_descriptor_ascii'
/usr/bin/ld: device.c:(.text+0x6f7): undefined reference to `libusb_get_string_descriptor_ascii'
/usr/bin/ld: device.c:(.text+0x71e): undefined reference to `libusb_get_string_descriptor_ascii'
/usr/bin/ld: device.c:(.text+0x738): undefined reference to `libusb_close'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_get_device_list':
device.c:(.text+0x7c3): undefined reference to `libusb_get_device_list'
/usr/bin/ld: device.c:(.text+0x82f): undefined reference to `libusb_get_config_descriptor'
/usr/bin/ld: device.c:(.text+0x83e): undefined reference to `libusb_get_device_descriptor'
/usr/bin/ld: device.c:(.text+0x8cb): undefined reference to `libusb_free_config_descriptor'
/usr/bin/ld: device.c:(.text+0x8f0): undefined reference to `libusb_ref_device'
/usr/bin/ld: device.c:(.text+0x946): undefined reference to `libusb_free_config_descriptor'
/usr/bin/ld: device.c:(.text+0x9dd): undefined reference to `libusb_free_device_list'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_find_device':
device.c:(.text+0xb8d): undefined reference to `libusb_unref_device'
/usr/bin/ld: device.c:(.text+0xc10): undefined reference to `libusb_ref_device'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_find_devices':
device.c:(.text+0xdef): undefined reference to `libusb_ref_device'
/usr/bin/ld: device.c:(.text+0xe56): undefined reference to `libusb_unref_device'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_free_device_list':
device.c:(.text+0xf15): undefined reference to `libusb_unref_device'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_get_device':
device.c:(.text+0xf84): undefined reference to `libusb_ref_device'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_unref_device':
device.c:(.text+0x104d): undefined reference to `libusb_unref_device'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_claim_if':
device.c:(.text+0x109b): undefined reference to `libusb_detach_kernel_driver'
/usr/bin/ld: device.c:(.text+0x10ba): undefined reference to `libusb_claim_interface'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_release_if':
device.c:(.text+0x10fd): undefined reference to `libusb_set_interface_alt_setting'
/usr/bin/ld: device.c:(.text+0x1109): undefined reference to `libusb_release_interface'
/usr/bin/ld: device.c:(.text+0x111e): undefined reference to `libusb_attach_kernel_driver'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_get_device_info':
device.c:(.text+0x21b4): undefined reference to `libusb_get_config_descriptor'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_open':
device.c:(.text+0x2252): undefined reference to `libusb_open'
/usr/bin/ld: device.c:(.text+0x2291): undefined reference to `libusb_ref_device'
/usr/bin/ld: device.c:(.text+0x22d8): undefined reference to `libusb_get_config_descriptor'
/usr/bin/ld: device.c:(.text+0x231f): undefined reference to `libusb_get_device_descriptor'
/usr/bin/ld: device.c:(.text+0x2398): undefined reference to `libusb_detach_kernel_driver'
/usr/bin/ld: device.c:(.text+0x23ba): undefined reference to `libusb_claim_interface'
/usr/bin/ld: device.c:(.text+0x23f8): undefined reference to `libusb_set_interface_alt_setting'
/usr/bin/ld: device.c:(.text+0x2404): undefined reference to `libusb_release_interface'
/usr/bin/ld: device.c:(.text+0x2416): undefined reference to `libusb_close'
/usr/bin/ld: device.c:(.text+0x241f): undefined reference to `libusb_unref_device'
/usr/bin/ld: device.c:(.text+0x2446): undefined reference to `libusb_free_transfer'
/usr/bin/ld: device.c:(.text+0x24bb): undefined reference to `libusb_alloc_transfer'
/usr/bin/ld: device.c:(.text+0x250c): undefined reference to `libusb_submit_transfer'
/usr/bin/ld: device.c:(.text+0x254e): undefined reference to `libusb_attach_kernel_driver'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_free_devh':
device.c:(.text+0x2740): undefined reference to `libusb_free_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_close':
device.c:(.text+0x27a7): undefined reference to `libusb_close'
/usr/bin/ld: device.c:(.text+0x27e1): undefined reference to `libusb_unref_device'
/usr/bin/ld: device.c:(.text+0x2810): undefined reference to `libusb_free_transfer'
/usr/bin/ld: device.c:(.text+0x2855): undefined reference to `libusb_close'
/usr/bin/ld: device.c:(.text+0x2876): undefined reference to `libusb_set_interface_alt_setting'
/usr/bin/ld: device.c:(.text+0x2882): undefined reference to `libusb_release_interface'
/usr/bin/ld: device.c:(.text+0x28cd): undefined reference to `libusb_attach_kernel_driver'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `_uvc_status_callback':
device.c:(.text+0x1cf): undefined reference to `libusb_submit_transfer'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_get_bus_number':
device.c:(.text+0x249): undefined reference to `libusb_get_bus_number'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_get_device_address':
device.c:(.text+0x259): undefined reference to `libusb_get_device_address'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): in function `uvc_ref_device':
device.c:(.text+0x102d): undefined reference to `libusb_ref_device'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(init.c.o): in function `_uvc_handle_events':
init.c:(.text+0x27): undefined reference to `libusb_handle_events_completed'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(init.c.o): in function `uvc_init':
init.c:(.text+0x94): undefined reference to `libusb_init'
/usr/bin/ld: /epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(init.c.o): in function `uvc_exit':
init.c:(.text+0x10d): undefined reference to `libusb_exit'
collect2: error: ld returned 1 exit status
make[5]: *** [/epics/src/base/configure/RULES_BUILD:213: uvcApp] Error 1
make[5]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/uvcApp/src/O.linux-x86_64'
make[4]: *** [/epics/src/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/uvcApp/src'
make[3]: *** [/epics/src/base/configure/RULES_DIRS:84: src.install] Error 2
make[3]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC/uvcApp'
make[2]: *** [/epics/src/base/configure/RULES_DIRS:84: uvcApp.install] Error 2
make[2]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs/uvcIOC'
make[1]: *** [/epics/src/base/configure/RULES_DIRS:84: uvcIOC.install] Error 2
make[1]: Leaving directory '/epics/src/support/areaDetector/ADUVC/iocs'
make: *** [/epics/src/base/configure/RULES_DIRS:84: iocs.install] Error 2
Some of the other methods I have tried include the following:
  • Copy libusb.a into ADSupport/lib/linux-x86_64 and add $(PROD_NAME)_LIBS += usb to the IOC makefile
  • Do the same as above but add to both library and IOC Makefiles
  • Copy the libusb.so files to ADSupport and try to link to them dynamically.
  • Reorder the links (usb first, uvc first)
Finally, I decided to try and (statically) build a simple executable with libuvc outside of the EPICS build system, and I seemingly get the same errors,
meaning that the issue is likely tied to how the library is being built. The following makefile gives the same undefined reference issue:
all:
     g++ -L. uvc_locater.cpp -o uvc_locater -lusb -luvc
clean:
     rm uvc_locater
I am not yet sure if this is still something I am not following, or if there is an issue with the CMake/PkgConfig configuration for libuvc.
Best Regards,
Jakub
Sent: Friday, August 14, 2020 6:09 PM
To: Wlodek, Jakub <[email protected]>; Johnson, Andrew N. <[email protected]>
Hi Jakub,
I think I see your problem.
In your IOC application Makefile you are not linking with the usb library.  That works OK when you are linking with libuvc.so because that shareable library itself is linked with libusb.so.
But when you build statically and link with libuvc.a it will not automatically link with libusb.so.  So in your IOC application Makefile you need to include
Sent: Friday, August 14, 2020 4:59 PM
To: Johnson, Andrew N.; Mark Rivers
Cc: EPICS tech-talk
Hi Mark, Andrew,
The libuvc.a and .so files are generated by the install-libuvc.sh script in the uvcSupport directory. The libraries are copied into os/HOST_ARCH and then installed to the lib directory at the top level of the driver by the Makefile in that directory. As far as I know that directory should be included by the build system by default. Whether or not I specify SYS_LIBS or just LIBS I see the library appearing in the link phase, I just get that missing reference error if I'm using the non SYS_LIBS link. I did some messing around with the build of the vendor library as well but haven't looked too much into it.
The uvc library cmake uses pkgconfig to link against libusb and libjpeg, so I was wondering if there was some incompatibilities in that it could be linking something dynamically when constructing libuvc.a?
Thanks for the quick reply,
Jakub
Sent: Friday, August 14, 2020 5:32:14 PM
To: Rivers, Mark L. <[email protected]>
Cc: Wlodek, Jakub <[email protected]>; EPICS tech-talk <[email protected]>
Hi Jakub,
To expand on Mark’s reply a little, if you do have a libuvc.a file elsewhere, you should be able to use this in your Makefile to link with it:
$(PROD_NAME)_LIBS += uvc
uvc_DIR = /path/to/the/library/directory
Note that when building static binaries the order of the entries in your _LIBS variable is important as the linker usually makes just one pass through the list in the order that the libraries appear in that variable.
- Andrew
On Aug 14, 2020, at 4:17 PM, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi Jakub,
At first, I used $(PROD_NAME)_SYS_LIBS to link to the support library I used for communicating with the device,
but I would like to change this to $(PROD_NAME)_LIBS since it would be my understanding that this would mean that the driver application
could be built entirely statically, making it more portable since then the support library wouldn't have to be installed and in the system path
during runtime.
I see from the ADUVC repository on Github that the name of that support library is uvc, but I don't see a libuvc.so or libuvc.a file as part of the repository.  Those must be elsewhere on your system?  Is that support library provided in both shareable library (.so) and static (.a) versions?  If it is only provided in .so form then you cannot include it in your application binary.  If it is provided as a .a file then you can include it in your binary when you build statically.
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Wlodek, Jakub via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Friday, August 14, 2020 3:13 PM
To: [email protected]<mailto:[email protected]>
Subject: Question about static linking in the EPICS build system
Hi all,
I have been working for some time on allowing fully static linking of an areaDetector driver I wrote some time ago:
https://github.com/areaDetector/ADUVC/tree/R1-4
At first, I used $(PROD_NAME)_SYS_LIBS to link to the support library I used for communicating with the device, but
during runtime.
When using SYS_LIBS, the driver library and IOC application build without issue, however, when I change to just LIBS, the library still
compiles OK, but I get many undefined reference errors when compiling the App:
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_get_scanning_mode':
ctrl-gen.c:(.text+0x5b): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_set_scanning_mode':
ctrl-gen.c:(.text+0xea): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_get_ae_mode':
ctrl-gen.c:(.text+0x17b): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_set_ae_mode':
ctrl-gen.c:(.text+0x20a): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_get_ae_priority':
ctrl-gen.c:(.text+0x29b): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o):ctrl-gen.c:(.text+0x32a): more undefined references to `libusb_control_transfer' follow
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_free_device_info':
device.c:(.text+0x4c6): undefined reference to `libusb_free_config_descriptor'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_get_device_descriptor':
device.c:(.text+0x58d): undefined reference to `libusb_get_device_descriptor'
device.c:(.text+0x5f1): undefined reference to `libusb_open'
device.c:(.text+0x618): undefined reference to `libusb_get_string_descriptor_ascii'
device.c:(.text+0x640): undefined reference to `libusb_get_string_descriptor_ascii'
device.c:(.text+0x668): undefined reference to `libusb_get_string_descriptor_ascii'
device.c:(.text+0x683): undefined reference to `libusb_close'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_get_device_list':
device.c:(.text+0x711): undefined reference to `libusb_get_device_list'
device.c:(.text+0x769): undefined reference to `libusb_get_config_descriptor'
device.c:(.text+0x77d): undefined reference to `libusb_get_device_descriptor'
device.c:(.text+0x81c): undefined reference to `libusb_free_config_descriptor'
device.c:(.text+0x83c): undefined reference to `libusb_free_device_list'
device.c:(.text+0x969): undefined reference to `libusb_free_config_descriptor'
device.c:(.text+0x996): undefined reference to `libusb_ref_device'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_find_device':
device.c:(.text+0xac2): undefined reference to `libusb_get_device_descriptor'
device.c:(.text+0xb09): undefined reference to `libusb_unref_device'
device.c:(.text+0xb51): undefined reference to `libusb_open
The support library in use depends on libusb and libjpeg, both of which are found during the cmake build for said library. It is built both statically and dynamically.
I ran nm on the static library, and I did see the libusb functrions listed:
                U _GLOBAL_OFFSET_TABLE_
0000000000000000 d isight_tag.6062
                U libusb_alloc_transfer
                U libusb_cancel_transfer
                U libusb_control_transfer
                U libusb_free_ss_endpoint_companion_descriptor
                U libusb_free_transfer
                U libusb_get_ss_endpoint_companion_descriptor
                U libusb_set_interface_alt_setting
                U libusb_submit_transfer
It is clear to me that this is some error I have in the linking process/configuration, but I can't seem to figure out what
specifically it could be. I have tried adding libusb to the LIBS for the ioc application (copying the statically compiled library to
ADUVC/lib/linux-x86_64), but this gave me the same error, and the same when I added libusb to SYS_LIBS.
I have had similar issues when trying to get a static build of OpenCV to link against an areaDetector application -
it works fine when building the intermediate libraries (plugins, driver lib), but when building the final IOC application I got undefined reference errors.
If anyone has an idea on what I should change, it would be much appreciated.
Thanks!
Jakub Wlodek
Complexity comes for free, simplicity you have to work for.
Re: Question about static linking in the EPICS build system Mark Rivers via Tech-talk
Question about static linking in the EPICS build system Wlodek, Jakub via Tech-talk
Re: Question about static linking in the EPICS build system Johnson, Andrew N. via Tech-talk
Re: Question about static linking in the EPICS build system Wlodek, Jakub via Tech-talk
Prev: Re: Question about static linking in the EPICS build system Wlodek, Jakub via Tech-talk
Next: Re: Question about static linking in the EPICS build system Mark Rivers via Tech-talk
