1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: ADEiger 1.8
From: "Miceli, Antonino via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>
Cc: "Piatak, Christopher" <[email protected]>
Date: Tue, 18 Aug 2020 22:28:34 +0000
We have an Eiger1 X 500k which recently got repaired and Dectris shipped with their 1.8 API. We see a few strange things.
1.) We can only get the device driver (EigerDetectorConfig) to load if eigerModel=2. I doubt they upgraded with the new Eiger2 chips, but I am double checking with Dectris. If we use eigerModel = 1 we get some Rest API errors.
2.) eiger2.template has an include for eigerBase.template. It says it can't open eigerBase.template. See below. We bypassed this problem by merging eigerBase.template into eiger1.template. Most PV fill except Firmware Version and Serial Number and the detector takes images ok. If we use eiger2.template (and eigerModel=2) we have more problems (not shown below or quantified yet).
Nino
[dpuser@xraydetector91 iocEiger]$ ./start_ioc_eiger
/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9
/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADEiger-1-8
####################!../../bin/linux-x86_64/eigerDetectorApp
< envPaths.linux
</local/config/envPaths.linux
epicsEnvSet("DPEPICS", "/local/DPbin/epics/epics_2020-03-17")
#epicsEnvSet("DPEPICS", "/local/DPbin/epics/epics_2018-12-06")
#epicsEnvSet("SYNAPPS", "synApps_5_8")
epicsEnvSet("SYNAPPS", "support-R6-1/synApps_6_1")
</local/DPbin/epics/epics_2020-03-17/DPenvPaths.linux
epicsEnvSet("SUPPORT","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support")
epicsEnvSet("EPICS_BASE","/local/DPbin/epics/epics_2020-03-17/base-7.0.3.1")
epicsEnvSet("ALIVE","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/alive-R1-1-1")
epicsEnvSet("ASYN","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/asyn-R4-39")
epicsEnvSet("AUTOSAVE","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("AREA_DETECTOR","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9")
epicsEnvSet("ADCORE","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADCore-R3-9")
epicsEnvSet("ALLEN_BRADLEY","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/allenBradley-2-3")
epicsEnvSet("BUSY","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("CALC","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("CAPUTRECORDER","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/caputRecorder-R1-7-2")
epicsEnvSet("DAC128V","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/dac128V-R2-9")
epicsEnvSet("DELAYGEN","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/delaygen-R1-2-1")
epicsEnvSet("DEVIOCSTATS","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/iocStats-3-1-16")
epicsEnvSet("DXP","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/dxp-R6-0")
epicsEnvSet("IP","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/ip-R2-20-1")
epicsEnvSet("IP330","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/ip330-R2-9")
epicsEnvSet("IPAC","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/ipac-2-15")
epicsEnvSet("IPUNIDIG","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/ipUnidig-2-11")
epicsEnvSet("LOVE","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/love-R3-2-7")
epicsEnvSet("MCA","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/mca-R7-8")
epicsEnvSet("MEASCOMP","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/measComp-R2-3")
epicsEnvSet("MODBUS","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/modbus-R3-0")
epicsEnvSet("MOTOR","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/motor-R7-1")
epicsEnvSet("OPTICS","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/optics-R2-13-3")
epicsEnvSet("QUADEM","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/quadEM-R9-2-1")
epicsEnvSet("SPECTRAPLUGINS","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/spectraPlugins-1-6")
epicsEnvSet("SNCSEQ","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("SOFTGLUE","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/softGlue-R2-8-2")
epicsEnvSet("SSCAN","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/sscan-R2-11-3")
epicsEnvSet("STD","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/std-R3-6")
epicsEnvSet("STREAM","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/StreamDevice-2-8-9")
epicsEnvSet("VAC","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/vac-R1-9")
epicsEnvSet("VME","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/vme-R2-9-2")
epicsEnvSet("XSPRESS3","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/xspress3")
epicsEnvSet("XXX","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/xxx-R6-1")
</local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADenvPaths.linux
epicsEnvSet("ADANDOR","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADAndor-R2-8")
epicsEnvSet("ADANDOR3","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADAndor3-master")
epicsEnvSet("ADMAR345","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADmar345-R2-2")
epicsEnvSet("ADMARCCD","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADmarCCD-R2-3")
epicsEnvSet("ADPILATUS","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADPilatus-R2-9)
ADenvPaths.linux line 5: Unbalanced quote.
epicsEnvSet("ADPIXIRAD","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADPixirad-R2-2")
epicsEnvSet("ADPROSILICA","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADProsilica-R2-5")
epicsEnvSet("ADMYTHEN","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADMythen-R2-1")
epicsEnvSet("ADPOINTGREY","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADPointGrey-R2-9")
epicsEnvSet("ADSIMDETECTOR","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADSimDetector-R2-10")
epicsEnvSet("ADEIGER","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADEiger-1-8")
epicsEnvSet("TOP","/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADEiger-1-8/iocs/eigerIOC")
epicsEnvSet("IOCBOOT", "/local/DPbin/epics/iocBoot/iocEiger/")
errlogInit(20000)
dbLoadDatabase("/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADEiger-1-8/iocs/eigerIOC/dbd/eigerDetectorApp.dbd")
eigerDetectorApp_registerRecordDeviceDriver(pdbbase)
#  Detector Pool Specific Things
< /local/config/xrd_config.epics
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("SUFFIX","_xrd91")
epicsEnvSet("SECTOR","dp_")
epicsEnvSet("LOCATION", "xraydetector91")
epicsEnvSet("ENGINEER", "DP")
epicsEnvSet("GROUP", "XSD-DET")
epicsEnvSet("DETECTOR", "eiger")
epicsEnvSet("PREFIX", "dp_eiger_xrd91:")
epicsEnvSet("IOC", "iocdp_eiger_xrd91")
# Load AliveRecord
dbLoadRecords("/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/alive-R1-1-1/aliveApp/Db/alive.db","P=dp_eiger_xrd91:,RHOST=164.54.100.11")
# Load DevIOCStats
dbLoadRecords("/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/iocStats-3-1-16/db/iocAdminSoft.db", "IOC=dp_eiger_xrd91")
#epicsEnvSet("PREFIX", "13EIG1:")
epicsEnvSet("PORT",   "EIG")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1030")
epicsEnvSet("YSIZE",  "1065")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CBUFFS", "500")
epicsEnvSet("EIGERIP", "10.42.41.10")
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADCore-R3-9/db")
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "5000000")
#epicsEnvSet("PREFIX", "$(SECTOR)$(DETECTOR)$(SUFFIX):$(PREFIX1)")
eigerDetectorConfig("EIG", "10.42.41.10", 2,0, 0)
dbLoadRecords("/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADEiger-1-8/db/eiger2.template", "P=dp_eiger_xrd91:,R=cam1:,PORT=EIG,ADDR=0,TIMEOUT=1")
Can't open include file "eigerBase.template"
Error at or before ""eigerBase.template"" in file "/local/DPbin/epics/epics_2020-03-17/support-R6-1/synApps_6_1/support/areaDetector-R3-9/ADEiger-1-8/db/eiger2.template" line 5
# Debug
#asynSetTraceMask("$(PORT)", 0, 0x11)
Re: ADEiger 1.8 J. Lewis Muir via Tech-talk
Prev: Re: ADPilatus and camserver version Mark Rivers via Tech-talk
Next: get the timestamp of a record as a human-readable string and restore it after rebooting Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: installing synApps on Ubuntu Mark Rivers via Tech-talk
Next: Re: ADEiger 1.8 J. Lewis Muir via Tech-talk
