Subject: Re: installing synApps on Ubuntu
From: Randall Cayford via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 20 Aug 2020 10:52:22 -0700
I found the problem.  The defaults for tar on centos 7 and Ubuntu 18 are different.  On centos, untaring synApps assigns the user who untars.  On Ubuntu (at least with the parameters I used) the assigned user appears to be the uid and gid of whoever created it.  I don’t know why compiling as root has a problem with this but the depends.pl script hangs in that case.  chown fixed the problem.
I have mostly successfully compiled synApps on Ubuntu now.  The dxp module won’t compile over some problem with finding functions in what appears to be libusb.  That one I haven’t solved.
Thanks.
Randall
> On Aug 20, 2020, at 7:39 AM, Engbretson, Mark S. <[email protected]> wrote:
> On the module that it is stuck on, do a make distclean, and then start a recompile there.  I have seen the same situation where something goes screwy with a time stamp so thinks that something has to be recompiled when it doesn't.
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Michael Davidsaver via Tech-talk
> Sent: Tuesday, August 18, 2020 8:43 PM
> To: Randall Cayford <[email protected]>
> Cc: [email protected]
> On 8/18/20 2:45 PM, Randall Cayford via Tech-talk wrote:
>> We must be missing something obvious but synApps won’t install on Ubuntu for us.  The problem step is make release hangs forever.  Some problem with perl but we don’t know what.
>> Steps:
>> install ubuntu 18 LTS
>> Install EPICS7
>> Unzip the synApps (6_1) tar file and edit config files run “make
>> release”
>> Wait forever….
> What, if anything, is printed while you are waiting?
>> Exact same procedure installs fine on Centos 7.  Since there isn’t a lot of chatter about this, it seems like we’re missing a step somewhere.  Anyone know what we need to do?
> I occasionally have builds get stuck in infinite loops, repeating the same set of steps until I interrupt.
> So far this hasn't happen often or predictably enough to do much troubleshooting.
Re: installing synApps on Ubuntu Johnson, Andrew N. via Tech-talk
Re: installing synApps on Ubuntu Mark Rivers via Tech-talk
installing synApps on Ubuntu Randall Cayford via Tech-talk
Re: installing synApps on Ubuntu Michael Davidsaver via Tech-talk
Prev: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers J. Lewis Muir via Tech-talk
Next: Re: installing synApps on Ubuntu Johnson, Andrew N. via Tech-talk
Prev: Re: installing synApps on Ubuntu Jemian, Pete R. via Tech-talk
