1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL]
From: "Thomas, Patrick via Tech-talk" <[email protected]>
To: "STARRITT, Andrew" <[email protected]>, "EPICS Tech Talk ([email protected])" <[email protected]>
Date: Thu, 20 Aug 2020 18:59:22 +0000
Hi Andrew,
Thank you. Do you mind if I ask how you were able to get the copy and paste to work?
Patrick
Sent: Tuesday, August 18, 2020 5:43 PM
To: Thomas, Patrick <[email protected]>; EPICS Tech Talk ([email protected]) <[email protected]>
Subject: RE: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL]
Hi Patrick,
I think medm must use a different drag-drop mechanism from that used by Qt.
The best I could do was use middle-click on medm to copy the PV name into the
copy-paste buffer, and then paste it to a Qt widget.
Regards
Andrew
From: Tech-talk <[email protected]> On Behalf Of Thomas, Patrick via Tech-talk
Sent: Saturday, 15 August 2020 6:15 AM
To: [email protected] Talk <[email protected]>
Subject: accepting channel name drops in Qt from MEDM
I was wondering if anyone has been able to get a Qt widget to accept channel name drops from MEDM?
Thank you,
Patrick
Re: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL] Johnson, Andrew N. via Tech-talk
RE: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Prev: Re: installing synApps on Ubuntu Johnson, Andrew N. via Tech-talk
Next: Re: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL] Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
