1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Receiving duplicate monitor values using CA PV Gateway
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 27 Aug 2020 16:19:09 +0000
Hi Ralph,
On Aug 27, 2020, at 9:45 AM, Ralph Lange via Tech-talk <[email protected]> wrote:
Now, in that -no_cache mode, when a monitor connection to the PV exists and an additional external client connects - what should the Gateway do?
It doesn't have the cached value, so it must do another get() on the inside to the IOC. When the answer to that get() arrives, it can't be distinguished from a monitor update. So with a list of clients for that PV, which ones should get the update, which shouldn’t?
Why can’t that ca_get_callback() be distinguished, couldn’t it use a different pFunc and/or pArg than the monitors use? That would allow the gets to trigger different behavior (i.e. not update the cached value or forward this event to the monitoring clients).
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Receiving duplicate monitor values using CA PV Gateway Ralph Lange via Tech-talk
Receiving duplicate monitor values using CA PV Gateway Juan F. Esteban Müller via Tech-talk
Prev: Re: Receiving duplicate monitor values using CA PV Gateway Ralph Lange via Tech-talk
Next: Re: Receiving duplicate monitor values using CA PV Gateway Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
