1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: CAEN R1470ET HVPS - Asyn + Stream Device auto connect does
From: "Balakrishnan, Namrata via Tech-talk" <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Balakrishnan, Namrata" <[email protected]>
Date: Wed, 2 Sep 2020 19:02:21 +0000
Hi Han, Mark,
> Is your ioc developed by your team or CAEN? I think CAEN has their own embedded IOC. I saw your model also in their EPICS support list.
Yes, we are using the database and protocol file from CAEN EPICS support but have the IOC modified for our environment.
> ?  If we close and open the port again, communication is reestablished.
> What do you mean by that? How did you do it?
We tried the sequence of toggling Autoconnect (.AUCT), Enable/Disable(.ENBL) and connect/Disconnect(.CNCT) on the asyn record. The communication was re-established within 30 minutes ( immediately one time).
But as Marcio mentioned, once disconnectOnReadTimeout was tried,  we have not been able to communicate with the device again. The system is still in this condition as we were not authorized to reboot the IOC, yet.
>Can you ping the CAEN device? Can you open a manual telnet connection to it on port 1470, which seems to be the port you are using?
We can ping the device. But telnet stays at 'connecting to the device' state. The IOC is online at this point but communication with the device is not established.
Thanks and regards,
Namrata
Re: CAEN R1470ET HVPS - Asyn + Stream Device auto connect does Paduan Donadio, Marcio via Tech-talk
Prev: areaDetctor NDPluginProcess Background Saving John Dobbins via Tech-talk
Next: Teledyne ISCO D Series pumps Wyman, Max D via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: areaDetctor NDPluginProcess Background Saving John Dobbins via Tech-talk
Next: Re: CAEN R1470ET HVPS - Asyn + Stream Device auto connect does Paduan Donadio, Marcio via Tech-talk
