Hi Pilar,
Thanks for clarification and additional information about the WR integration work Seven Solutions have done. I'm sure I’ll be in touch with more
questions!
Cheers,
Will
Sent: 01 September 2020 16:55
To: Frank, William (STFC,RAL,ISIS) <[email protected]>; [email protected]
Subject: Re: PTP hardware timestamps in EPICS facilities
I´m part of the team of Seven Solutions involved in the integration of White Rabbit Solutions for particle accelerators.
As you have mentioned in your email, some of our WR solutions are currently in operation in LIPAc as part of the IFMIF/EVEDA project with outstanding performance.
The contributions of Seven Solution to the mentioned accelerator have been:
- The Radio Frequency and Time distribution based on White Rabbit products: they offer the distribution of global time references to all the nodes in the network in a deterministic and dependable way),
- RF Control System (LLRF) and Beam Instrumentation (BPM): both solutions include EPICS support and the use of WR for the Master Oscillator distribution and timing synchronization (postmortem, fast interlocks or control)
Feel free to contact me if you have any further questions.
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L
and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions
or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
- Re: PTP hardware timestamps in EPICS facilities Pilar Gil via Tech-talk
RE: PTP hardware timestamps in EPICS facilities Frank, William (STFC, RAL, ISIS) via Tech-talk
Re: PTP hardware timestamps in EPICS facilities Hamadyk, Paul (DLSLtd, RAL, LSCI) via Tech-talk
<2020>
2025
2026
AreaDetector: PVs from driver created parameters not updating David Vine via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
