Subject: New releases of ADGenICam, ADAravis, and ADSpinnaker
To: "[email protected] ([email protected])" <[email protected]>
Date: Sun, 20 Sep 2020 20:46:36 +0000
Folks,
ADGenICam R1-5 is now available.  This is from the release notes:
* Changed the code and the Makefiles to avoid using shareLib.h from EPICS base.
  Added new header file ADGenICamAPI.h that is used to control whether
  functions, classes, and variables are definined internally to the library or externally.
  This is the mechanism now used in EPICS base 7.
  It makes it much easier to avoid mistakes in the order of include files that cause external
  functions to be accidentally exported in the DLL or shareable library.
  This should work on all versions of base, and have no impact on user code.
* Added fix for cameras that don't support GenICam feature AcquisitionMode=MultiFrame.
* Added 0.1 second delay between the pausing of acquisition and setting camera parameter, and
  0.1 second delay after setting a parameter and resuming acquisition.
* Added support for new cameras:
  - AVT_Mako_G158C.xml
  - Basler_piA640_210gm.xml
  - FLIR_BFS_70S7M.xml
Home page: https://github.com/areaDetector/ADGenICam
ADAravis R2-0 is now available.  This is from the release notes:
* Updated from aravis 0.7.2 to 0.8.1.  The aravis API has changed, so sites will need to update their
  local aravis installation to 0.8.1.
* Fixed a problem with GenICam boolean features.  Previously the code was calling the aravis functions
  for integer features, which did not work.  It was changed to call the functions for boolean features,
  and it now works correctly.
* Removed ARHWImageMode. This was presumably used to support cameras that did not support
  the GenICam AcquisitionMode feature.  It seems all cameras now support that, and it
  was not tested that it actually worked.
* Changed printf() calls to asynPrint.  This required adding a new method.
* Added an example of adding the GenICam feature PV $(P)cam1:GC_Gamma to autosave in
  the iocAravis directory.  The auto_settings.req and st.cmd.BlackflyS_13Y3M files were changed.
Home page: https://github.com/areaDetector/ADAravis
ADSpinnaker R3-0 is now available.  This is from the release notes:
* Updated Spinnaker version from 1.2.0 to 2.0.0.147.
  Windows users will need to update their local install of Spinnaker to this version.
  Linux users do not need to do anything, since all required files are included with ADSpinnaker.
* The BufferUnderrunCount record has changed to LostFrameCount, because this is what the feature
  is called in the new version of the SDK.
Home page: https://github.com/areaDetector/ADSpinnaker
Prev: areaDetector and ADCore R3-10 released Mark Rivers via Tech-talk
Next: How to build MEDM (Jetson nano) 신동호 via Tech-talk
