1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to build MEDM (Jetson nano)
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS tech-talk <[email protected]>, 신동호 <[email protected]>
Date: Tue, 22 Sep 2020 02:44:20 +0000
Unfortunately there is no CONFIG_SITE.linux-aarch64.linux-aarch64 file in the extensions/configure/os directory; Dong Ho is the first person to use this host architecture (which is the 64-bit version of linux-arm and has only just been added to Base) and I suspect may have some difficulties.
My first instinct would be to copy the CONFIG_SITE.linux-x86.linux-x86 file to the name given above and edit it to match, but there are quite a lot of old and irrelevant paths in that file. I suspect the configuration for Ubuntu on linux-aarch64 would be closer to that of linux-x86_64, but the latter file just pulls in and overrides the settings from the 32-bit linux-x86 target. Maybe that would still work though.
I wish I had time to help, but I don't. The whole extensions build area could use cleaning up or replacing, but someone will have to volunteer to take that on, anyone interested?
- Andrew
On Sep 21, 2020, at 8:43 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
CONFIG_SITE is meant to be locally edited for your site. Just make the changes you need for your arch.
If you get build errors post them here.
Sent from my iPhone
On Sep 21, 2020, at 8:31 PM, 신동호 <[email protected]> wrote:
Hi, Mark
I followed the instruction you gave.
To build medm, CONFIGURE_SITE* file for linux-aarch64 is needed.
But I didn't find in the directory ../configure/os.
I guess most extensions for EPICS do not support aarch64.
- Dong Ho, SHIN
-----Original Message-----
To:     "신동호" <[email protected]>;
Cc:     "[email protected]" <[email protected]>;
Sent:  2020-09-21 (월) 21:20:06 (UTC+09:00)
First download this module:
https://github.com/epics-extensions/extensions
Then cd to that directory, and in that directory install this module:
https://github.com/epics-extensions/medm
The extensions/README explains how to build it.
https://github.com/epics-extensions/extensions/blob/master/README
From: Tech-talk <[email protected]> on behalf of 신동호 via Tech-talk <[email protected]>
Sent: Monday, September 21, 2020 4:00 AM
To: [email protected]
Subject: How to build MEDM (Jetson nano)
Dear all,
I have succeeded to install EPICS base (Rver 7) with aysn & streamdevice supports.
And now I want to get install GUI tool, MEDM. Would you explain more detail how to build MEDM?
- Dong Ho, SHIN
[https://gov-dooray.com/mail-receipts?img=3768747754637167-255f3328d91a814f-2764576884bb5a9c-27645b06ab92d51d.gif]
Complexity comes for free, simplicity you have to work for.
Re: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
How to build MEDM (Jetson nano) 신동호 via Tech-talk
Re: How to build MEDM (Jetson nano) Mark Rivers via Tech-talk
RE: Re: How to build MEDM (Jetson nano) 신동호 via Tech-talk
Prev: Re: How to build MEDM (Jetson nano) Mark Rivers via Tech-talk
Next: Does edm static widget support chinese input? Silver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
