1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: AW: autosave 5-10-1 on RTEMS-4.10.2, mount failed
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 22 Sep 2020 13:02:03 +0000
Hello Hu Yong,
yes, my autosave folder exists and is reachable. I Just found out that it is better to use nfsMount() instead of save_restoreSet_NFSHost().
The req-Files are already generated and are in the autosave directory.
When the IOC is writing the sav-Files it looks like this:
/autosave/iocRtems # ll
total 196
-rw-rw-rw- 1 bl     users   6952 Sep 16 11:21 auto_positions.req
-rw-rw-r-- 1 nobody nobody  3862 Sep 22 14:43 auto_positions.sav
-rw-rw-r-- 1 nobody nobody  3862 Sep 22 14:43 auto_positions.savB
-rw-rw-rw- 1 nobody nobody  3862 Sep 22 14:42 auto_positions.sav_200922-124257
-rw-rw-rw- 1 bl     users   6864 Sep 16 11:24 auto_settings.req
-rw-rw-r-- 1 nobody nobody 56574 Sep 22 14:43 auto_settings.sav
-rw-rw-r-- 1 nobody nobody 56574 Sep 22 14:43 auto_settings.savB
-rw-rw-rw- 1 nobody nobody 56574 Sep 22 14:42 auto_settings.sav_200922-124258
They belong to nobody… Probably I’m still missing some proper DHCP/DNS configuration?
But anyway, the IOC is now saving/loading the correct settings.
Regards
Michael
Von: Hu, Yong <[email protected]>
Gesendet: Montag, 21. September 2020 22:03
An: Sintschuk, Michael <[email protected]>; EPICS tech-talk <[email protected]>
Betreff: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed
Hi Michael,
1) You said this:
And this is the exports file-entry for my autosave folder:
/autosave          172.17.8.0/24(rw,no_subtree_check) 192.168.99.0/24(rw,no_subtree_check)
Have you really created a folder “autosave” under the root directory “/”?
Or you actually created “autosave” under /soft/epics/IOC/iocRtems/? If so, you need to do this in your NFS exports file-entry:
/soft/epics/IOC/iocRtems                  172.17.8.0/24(rw,no_subtree_check) 192.168.99.0/24(rw,no_subtree_check)
And you need to change the autosave-related-path in your st.cmd accordingly:
set_savefile_path("/soft/epics/IOC/iocRtems/autosave")
set_requestfile_path("/soft/epics/IOC/iocRtems/autosave")
save_restoreSet_NFSHost("nfsioc","192.168.99.1")
Basically, on your NFS server, you need to create a directory “autosave” and make sure it is writable: mkdir -p autosave; chmod 777 -R autosave;
2) I do not see how the autosave request files (auto_positions.req, auto_settings.req) are provided/generated. If you are using “info” in your .db, you should use something like below in your st.cmd to automatically generate those request files:
makeAutosaveFileFromDbInfo("/soft/epics/IOC/iocRtems/autosave/auto_positions.req ", "autosaveFields_pass0")
makeAutosaveFileFromDbInfo("/soft/epics/IOC/iocRtems/autosave/auto_ settings.req ", "autosaveFields_pass0")
makeAutosaveFileFromDbInfo("/soft/epics/IOC/iocRtems/autosave/auto_ settings.req ", "autosaveFields_pass1")
Good luck!
Yong Hu
NSLS-II Controls Group
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: "Sintschuk, Michael" <[email protected]>
Date: Monday, September 21, 2020 at 5:32 AM
Subject: autosave 5-10-1 on RTEMS-4.10.2, mount failed
Hi all,
I’m setting up an IOC, BASE-3.15.7 and autosave 5-10-1, on an Motorola board MVME-2100 using RTEMS-4.10.2.
The comand save_restoreSet_NFSHost fails on it with mount failed: Invalid argument . But my IOC is using nfs to mount it’s “st.cmd” file, so I don’t know why it is not seeing the autosave folder, that is also exported via NFS.
Here is my IOC Start-up:
Copyright Motorola Inc. 1988 - 2004, All Rights Reserved
PPC5 Debugger/Diagnostics Release Version 1.1 - 08/20/2004 RM04
COLD Start
Local Memory Found =02000000 (&33554432)
MPU Clock Speed =200Mhz
BUS Clock Speed =67Mhz
Reset Vector Location  : ROM Bank B
Mezzanine Configuration: Single-MPU
Current 60X-Bus Master : MPU0
Idle MPU(s)            : NONE
L2Cache:       NONE
System Memory: 32MB, Parity NOT Enabled (Non-Parity-Memory Detected)
SelfTest/Boots about to Begin... Press <BREAK> at anytime to Abort ALL
NetBoot about to Begin... Press <ESC> to Bypass, <SPC> to Continue
Network Booting from: DEC21143, Controller 0, Device 0
Device Name: /pci@fec00000/pci1011,19@e,0:0,0
Loading: epics/iocRtems/iocRtems.boot
Client IP Address      = 192.168.99.250
Server IP Address      = 192.168.99.1
Gateway IP Address     = 0.0.0.0
Subnet IP Address Mask = 255.255.255.0
Boot File Name         = epics/iocRtems/iocRtems.boot
Argument File Name     = /soft/epics/IOC/iocRtems/iocBoot/iocRtems/st.cmd
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&1183560, Bytes Loaded =&1183560
Bytes/Second   =&591780, Elapsed Time =2 Second(s)
Residual-Data Located at: $01F5511C
Model: Motorola MVME2101          (e2)
Serial: MOT0BC614E
Processor/Bus frequencies (Hz): 200003328/66667776
Time Base Divisor: 4000
Memory Size: 2000000
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
done
Now booting...
Welcome to rtems-4.10.2(PowerPC/Generic (classic FPU)/mvme2100) on MVME 2100
pci : Configuring interrupt routing for 'MVME 2100'
pci : Device 0:0x00:0 routed to interrupt_line 16
pci : Device 0:0x0D:0 routed to interrupt_line 23
pci : Device 0:0x0E:0 routed to interrupt_line 17
WARNING: unable to allocate page table, keeping DBAT0
WARNING: unable to setup page tables VME bridge must share PCI space
OpenPIC Version 1.2 (1 CPUs and 24 IRQ sources) at 0xFCE40000
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 1
Overriding NumSources (24) from configuration with 16
OpenPIC timer frequency is 8333472 Hz
Universe II PCI-VME bridge detected at 0xFCDFF000, IRQ 23
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
1:    0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
2:    0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0:    0xC0000000 0x02000000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
Registering /dev/console as minor 0 (==/dev/ttyS0)
***** RTEMS Version: rtems-4.10.2(PowerPC/Generic (classic FPU)/mvme2100) *****
Startup.
***** Initializing network *****
dec2114x : unit 1 base address FCDFEC00.
dec2114x : driver attached
dec2114x : driver tasks created
dec2114x : 00:01:AF:15:AD:97   name 'dc1', io BFDF80, mem FCDFEC00, int 17
dec2114x: Installing IRQ 17
***** Initializing NFS *****
Mount 192.168.99.1:/soft on /soft
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
Warning: No timezone information, times will be displayed in UTC.
***** Starting EPICS application *****
## Example RTEMS startup script
## You may have to change iocRtems to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocRtems")
epicsEnvSet("TOP","/soft/epics/IOC/iocRtems")
epicsEnvSet("MODULES","/soft/epics/inst-3.15.7")
epicsEnvSet("ASYN","/soft/epics/inst-3.15.7/asyn/4-40-1")
epicsEnvSet("MOTOR","/soft/epics/inst-3.15.7/motor/7-2-1")
epicsEnvSet("PSEUDOMOTAPPS","/soft/epics/inst-3.15.7/pseudoMotors/1-1")
epicsEnvSet("SEQLONG","/soft/epics/inst-3.15.7/seqlong-1-0")
epicsEnvSet("SSCAN","/soft/epics/inst-3.15.7/sscan/2-11-3")
epicsEnvSet("CALC","/soft/epics/inst-3.15.7/calc/3-7-4")
epicsEnvSet("AUTOSAVE","/soft/epics/inst-3.15.7/autosave/5-10-1")
epicsEnvSet("IK342","/soft/epics/inst-3.15.7/IK342")
epicsEnvSet("EPICS_BASE","/soft/epics/base")
cd "/soft/epics/IOC/iocRtems"
dbLoadDatabase("dbd/iocRtems.dbd")
iocRtems_registerRecordDeviceDriver(pdbbase)
## Load record instances
#dbLoadTemplate("db/iocRtems.substitutions")
dbLoadRecords("db/iocRtems.db", "user=bl")
#var drvOms58debug 10
oms58Setup(11, 0x1000,180,5,2)
IK342Setup(1,0xC000)
set_savefile_path("/autosave/iocRtems")
set_requestfile_path("/autosave/iocRtems")
Mount nfsioc:/autosave/iocRtems on /autosave/iocRtems
save_restore: Can't mount '/autosave/iocRtems'
set_pass0_restoreFile("auto_positions.sav")
set_pass0_restoreFile("auto_settings.sav")
#set_pass0_restoreFile("pseudoMotor.sav")
set_pass1_restoreFile("auto_settings.sav")
#set_pass1_restoreFile("detectors.sav")
save_restoreSet_status_prefix("iocRtems:")
save_restoreSet_DatedBackupFiles(1)
save_restoreSet_NumSeqFiles(1)
# Time interval between sequenced backups
save_restoreSet_SeqPeriodInSeconds(600)
iocInit
Starting iocInit
## EPICS R3.15.7
## EPICS Base built Sep  1 2020
*** IK342:  Running IK342 Initialization IK342_drv_init ***
 1 nIK342Cards, 0xc000. baseAddr
libbspExt - Warning: it seems that MCP support is not available on your CPU
                     or not implemented by your board. Address probing must
                     be performed in polling mode with interrupts disabled
../drvIK342.c: card 0 present at addr 9FFFC000
version  FF00
reboot_restore: entry for file 'auto_positions.sav'
reboot_restore: Found filename 'auto_positions.sav' in restoreFileList.
*** restoring from '/autosave/iocRtems/auto_positions.sav' at initHookState 6 (before record/device init) ***
save_restore: Can't open file '/autosave/iocRtems/auto_positions.sav'.
save_restore: Trying backup file '/autosave/iocRtems/auto_positions.savB'
save_restore: Can't open file '/autosave/iocRtems/auto_positions.savB'.
save_restore: Can't figure out which seq file is most recent,
save_restore: so I'm just going to start with '/autosave/iocRtems/auto_positions.sav0'.
save_restore: Trying backup file '/autosave/iocRtems/auto_positions.sav0'
save_restore: Can't open file '/autosave/iocRtems/auto_positions.sav0'.
save_restore: Can't find a file to restore from...save_restore: ...last tried '/autosave/iocRtems/auto_positions.sav0'. I give up.
save_restore: **********************************
save_restore: Can't open save file.reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from '/autosave/iocRtems/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore: Can't open file '/autosave/iocRtems/auto_settings.sav'.
save_restore: Trying backup file '/autosave/iocRtems/auto_settings.savB'
save_restore: Can't open file '/autosave/iocRtems/auto_settings.savB'.
save_restore: so I'm just going to start with '/autosave/iocRtems/auto_settings.sav0'.
save_restore: Trying backup file '/autosave/iocRtems/auto_settings.sav0'
save_restore: Can't open file '/autosave/iocRtems/auto_settings.sav0'.
save_restore: Can't find a file to restore from...save_restore: ...last tried '/autosave/iocRtems/auto_settings.sav0'. I give up.
save_restore: Can't open save file.init_record: card = 0   channel = 0
init_record: card = 0   channel = 1
init_record: card = 0   channel = 2
init_record: card = 0   channel = 3
*** restoring from '/autosave/iocRtems/auto_settings.sav' at initHookState 7 (after record/device init) ***
save_restore: Can't open save file.iocRun: All initialization complete
epicsThreadSleep(10.)
create_monitor_set("auto_positions.req", 5, "NULL")
save_restore:readReqFile: unable to open file auto_positions.req. Exiting.
create_monitor_set("auto_settings.req", 5, "NULL")
mount failedsave_restore:readReqFile: unable to open file auto_settings.req. Exiting.
: #create_monitor_set("pseudoMotor.req",5, "NULL")
Invalid argument#create_monitor_set("detectors.req",5, "NULL")
#fdbrestore("DMMarm.sav")
## Start any sequence programs
#seq(sncxxx, "user=bl")
192.168.99.250> save_restore: Can't connect to all status PV(s)
save_restore: attempting to remount filesystem
save_restore: failed to remount '/autosave/iocRtems'
192.168.99.250>192.168.99.250>
This is how my dhcpd.conf for the MVME-2100 looks like (it is OpenSuse Leap 15.1):
   group {
    use-host-decl-names on;
    always-reply-rfc1048 on;
    server-name bam01;
    host vmecpu-20 {
      option host-name iocRtems;
      option script-name "/soft/epics/IOC/iocRtems/iocBoot/iocRtems/st.cmd";
      hardware ethernet 00:01:af:15:ad:97;
      fixed-address 192.168.99.250;
      filename "epics/iocRtems/iocRtems.boot";
      next-server 192.168.99.1;
The command save_restoreSet_NFSHost("nfsioc","192.168.99.1") is using the CNAME-Record “nfsioc” which is just an alias for my NFS-Server.
If I set it to the real name of my NFS-Server (“bam01”), it results in the same error: mount failed: Invalid argument
So what argument am I missing? Does anyone know?
Regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Johnson, Andrew N. via Tech-talk
autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Hu, Yong via Tech-talk
Prev: AW: autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
Next: Re: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Hu, Yong via Tech-talk
Next: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Johnson, Andrew N. via Tech-talk
