Thanks for the comments everyone.
It looks like a combination of including the .so libs in the IOC package, setting LD_LIBRARY_PATH to point to the libs, and using LINKER_USE_RPATH=NO is a winner.
The new ORIGIN option for LINKER_USE_RPATH seems like a great feature for this case, but it looks like this was added in base 7.0.3.1 and we're currently using 3.15.5.
Thanks again.
Mike
If you want to stop the EPICS build system from embedded the built-host’s path into the IOC executables you can edit the CONFIG_SITE file of the application that builds the IOC and set
LINKER_USE_RPATH=NO in it. That will require you to set LD_LIBRARY_PATH or use one of the other mechanisms (/etc/ld.so.conf) to set to path to the .so files, but it will stop the loader from searching the incorrect path for them.
With a recent versions of Base you could also try out the newer LINKER_USE_RPATH=ORIGIN mechanism which embeds a relative path into the executable and avoids your having to set LD_LIBRARY_PATH, so as long as you keep the standard bin/<host> and
lib/<host> paths in your copy of the IOC application. I think there should be documentation on using that in the Release Notes file, if it’s not mentioned in your installed copy of Base your version is too old to use it.
- Andrew
Hi Michael,
Whenever I need to copy IOC executables that rely on vendor shared libraries, I put the .so libraries with the distribution,
and include a script that sets the LD_LIBRARY_PATH environment variable to include the location of those libraries
as a part of the IOC startup sequence. This way the user can start the IOC without having to install these
shared libraries to a system location that might require root access.
Best,
Jakub
Hi Mike,
Ø So
it's not a static build, but I guess this is expected. I'm guessing that until the vendor releases source code or archive libraries, that there's just no way around this?
Ø I
suppose one option is to drop the .so libraries in a directory whose path exists on both the development and production servers, e.g. /usr/local/lib/ or somewhere like that?
I think it as close to a static build as you can get, given that the vendor distributes .so files. In my experience vendors in the past used to distribute both .a and .so files, but recently only .so files. The same problem exists
on Windows, where the vendor almost always builds their library dynamically and distributes .lib and .dll files.
My practice in areaDetector has been the following:
- For
Linux areaDetector includes the .so files. This is required so that anyone can build the package without having to install anything from the vendor on their machine. It also means, for example that all you need to copy to another machine is ADVimba/bin/rhel7-x86_64/
and ADVimba/lib/rhel7-x86_64/, ADVimba/dbd, and ADVimba/db (plus OPI files).
- For
Windows areaDetector includes the .lib files, but not the .dll files. The .lib files are all that is required to build the application. The .dll files are needed to run the application. I do this because the vendor normally also installs drivers as part
of their package, and so a local installation is usually necessary anyway, and that will include the .dlls. I have also found vendors happy to allow me to distribute .h and .lib files, and less happy for me to distribute .dll files. The .lib file defines
the API, and so typically needs to be updated less often than the .dll which defines the implementation and can be changed to fix bugs without changing the .lib file.
Ø Is
there a better way of dealing with this in the EPICS build system, or some other clever trick?
Ø I
guess this could be viewed as a more general question of how to do a static IOC build when you only have shared object libraries.
I think you need to accept that you will need to copy the .so files as well as the executables. After all, you must also already be copying the dbd/ files and db/ files, not just the executable.
I've been testing ADVimba on both rhel6 and rhel7 and it seems to be working well. Thanks a lot for your work on this module Mark.
I'm trying to use this module with a static IOC build (i.e. setting SHARED_LIBRARIES=NO and STATIC_BUILD=YES).
We build all IOCs in this way and then copy them over to and run them on a production server with the same architecture, which doesn't have access to our development fileserver.
As you know, for linux the vendor support has two parts:
vimbaSupportC --> No source code, no archive (.a) libraries, only shared object (.so) libraries
vimbaSupportCPP --> Built by ADVimba from vendor source code
And the libs section of the IOC Makefile looks like this:
# Add locally compiled object code
PROD_LIBS_WIN32 += VimbaCPP VimbaC VimbaImageTransform
PROD_LIBS_Linux += VimbaCPP
PROD_SYS_LIBS_Linux += VimbaC VimbaImageTransform
If I build my 'static' IOC, I get a binary which needs the .so libraries:
$ ldd bin/rhel7-x86_64/vimbaApp
linux-vdso.so.1 => (0x00007ffe985dc000)
libVimbaC.so => /afs/ slac.stanford.edu/g/spear/vol8/epics/modules/areaDetector/R3.9/ADVimba/lib/rhel7-x86_64/libVimbaC.so (0x00007ff613966000)
libVimbaImageTransform.so => /afs/ slac.stanford.edu/g/spear/vol8/epics/modules/areaDetector/R3.9/ADVimba/lib/rhel7-x86_64/libVimbaImageTransform.so (0x00007ff61366c000)
libX11.so.6 => /lib64/libX11.so.6 (0x00007ff61332e000)
libXext.so.6 => /lib64/libXext.so.6 (0x00007ff61311c000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007ff612f00000)
libreadline.so.6 => /lib64/libreadline.so.6 (0x00007ff612cba000)
libncurses.so.5 => /lib64/libncurses.so.5 (0x00007ff612a93000)
libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007ff612869000)
librt.so.1 => /lib64/librt.so.1 (0x00007ff612661000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007ff61245d000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007ff612156000)
libm.so.6 => /lib64/libm.so.6 (0x00007ff611e54000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007ff611c3e000)
libc.so.6 => /lib64/libc.so.6 (0x00007ff611870000)
libxcb.so.1 => /lib64/libxcb.so.1 (0x00007ff611648000)
/lib64/ld-linux-x86-64.so.2 (0x00007ff613c3a000)
libXau.so.6 => /lib64/libXau.so.6 (0x00007ff611444000)
$ objdump -p bin/rhel7-x86_64/vimbaApp | grep NEEDED
NEEDED libVimbaC.so
NEEDED libVimbaImageTransform.so
NEEDED libX11.so.6
NEEDED libXext.so.6
NEEDED libpthread.so.0
NEEDED libreadline.so.6
NEEDED libncurses.so.5
NEEDED libtinfo.so.5
NEEDED librt.so.1
NEEDED libdl.so.2
NEEDED libstdc++.so.6
NEEDED libm.so.6
NEEDED libgcc_s.so.1
NEEDED libc.so.6
So it's not a static build, but I guess this is expected. I'm guessing that until the vendor releases source code or archive libraries, that there's just no way around this?
I suppose one option is to drop the .so libraries in a directory whose path exists on both the development and production servers, e.g. /usr/local/lib/ or somewhere like that?
Is there a better way of dealing with this in the EPICS build system, or some other clever trick?
I guess this could be viewed as a more general question of how to do a static IOC build when you only have shared object libraries.
Quick update on this. A power cycle on both cameras fixed both issues.
However, we will plan to move to ADVimba regardless.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Pearson, Matthew R. via Tech-talk
Sent: Friday, July 24, 2020 10:07 AM
To: Mark Rivers <[email protected]>
Cc: [email protected]
Subject: [EXTERNAL] RE: ADProsilica crashing on RHEL7 3.10.0-1127
Hi Mark & Mike,
The camera is reachable. I tried a non-existent camera, and the IOC starts up normally with the usual message:
prosilicaConfig("AVT.CAM", 10.111.24.99, 100, 0, 0, 0, 10)
2020/07/24 09:59:13.252 prosilica:connectCamera: Cannot find camera 10.111.24.99
prosilica:prosilica: cannot connect to camera 10.111.24.99, manually connect when available.
Also thanks Mike for the info. I also see it affecting a sub-set of our cameras. The two affected cameras are one beamline, and we have a working camera on a different beamline (same Linux versions though). Out of the 2 affected cameras, one crashes with the
same seg fault, and the other acts differently:
prosilicaConfig("AVT.CAM", 10.111.24.11, 100, 0, 0, 0, 10)
2020/07/24 10:03:18.670 prosilica:connectCamera: unable to get sensor data on camera 5122144
prosilica:prosilica: cannot connect to camera 10.111.24.11, manually connect when available.
I will be able to head in to the beamline on Monday to power cycle the cameras. We have more than a week before our facility starts up again, so we may try switching to ADVimba.
Cheers,
Matt
Sent: Thursday, July 23, 2020 7:49 PM
To: Pearson, Matthew R. <[email protected]>
Subject: [EXTERNAL] Re: ADProsilica crashing on RHEL7 3.10.0-1127
Hi Matt,
Is that camera reachable? Does it crash if you try to connect to a non-existent camera?
I am updating one of our Linux machines to that version of Centos 7. I can see if I have the problem. All of our production AVT/Prosilica cameras are now running ADVimba, but I can try a test with ADProsilica.
From: Tech-talk <[email protected]> on behalf of Pearson, Matthew R. via Tech-talk <[email protected]>
Sent: Thursday, July 23, 2020 4:41 PM
To: [email protected]
Subject: ADProsilica crashing on RHEL7 3.10.0-1127
We've been using ADProsilica to control our AVT Manta cameras for many years. This uses the legacy PvApi library from AVT. It seems to be failing under our latest RHEL7 update (3.10.0-1127.13.1.el7.x86_64).
I've pasted the stack trace below. The problem seems to be deep inside libPvAPI.a, which is linked into libprosilica.so. libPvAPI.a was provided by AVT, but the last build was in 2015.
Anyone else seen this issue?
I know there is a newer areaDetector driver for AVT cameras, so it may be the case that we just have to switch to using that.
Cheers,
Matt
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7b61a7a in PGc::TiXmlAttributeSet::Find(char const*) const () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
Missing separate debuginfos, use: debuginfo-install glibc-2.17-307.el7.1.x86_64 jbigkit-libs-2.0-11.el7.x86_64 libgcc-4.8.5-39.el7.x86_64 libjpeg-turbo-1.2.90-8.el7.x86_64 libstdc++-4.8.5-39.el7.x86_64 libtiff-4.0.3-32.el7.x86_64 ncurses-libs-5.9-14.20130511.el7_4.x86_64
readline-6.2-11.el7.x86_64 sssd-client-1.16.4-37.el7_8.3.x86_64 zlib-1.2.7-18.el7.x86_64
(gdb)
(gdb)
(gdb)
(gdb)
(gdb) bt
#0 0x00007ffff7b61a7a in PGc::TiXmlAttributeSet::Find(char const*) const () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#1 0x00007ffff7b61acd in PGc::TiXmlElement::Attribute(char const*) const () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#2 0x00007ffff7b683db in SearchForNamedNode(PGc::TiXmlNode*, char const*) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#3 0x00007ffff7b4dd55 in cGcContext::GetNode(char const*, bool) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#4 0x00007ffff7b60ad2 in cGcBoolNode::SetupFromXML(PGc::TiXmlNode*, PGc::TiXmlNode*) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#5 0x00007ffff7b4bef5 in cGcContext::BuildNodeFromXML(char const*, PGc::TiXmlNode*) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#6 0x00007ffff7b4fcc2 in cGcContext::ProcessXMLDocument() () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#7 0x00007ffff7b5020c in cGcContext::LoadXMLString(char const*, bool) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#8 0x00007ffff7b4ba12 in cGcInterface::InjectXMLString(char const*, bool) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#9 0x00007ffff7b3730f in cPvGigEGenicam::Opening(unsigned int, unsigned int) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#10 0x00007ffff7b43071 in pPvRawCamera::Open(unsigned int) () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#11 0x00007ffff7b303c5 in PvCameraOpenByAddr () from /home/controls/epics/ADProsilica/master/lib/linux-x86_64/libprosilica.so
#12 0x00007ffff7b2b3d7 in prosilica::connectCamera (this=0x6b7030) at ../prosilica.cpp:1317
#13 0x00007ffff7b2d952 in prosilica::prosilica (this=0x6b7030, portName=0x6b6ff0 "AVT.CAM", cameraId=0x6b6ff8 "10.111.24.10", maxBuffers=100, maxMemory=0, priority=0, stackSize=0,
maxPvAPIFrames=10) at ../prosilica.cpp:1808
#14 0x00007ffff7b2d14b in prosilicaConfig (portName=0x6b6ff0 "AVT.CAM", cameraId=0x6b6ff8 "10.111.24.10", maxBuffers=100, maxMemory=0, priority=0, stackSize=0, maxPvAPIFrames=10)
at ../prosilica.cpp:1689
#15 0x00007ffff7b2da2b in configprosilicaCallFunc (args=0x61ff60) at ../prosilica.cpp:1839
#16 0x00007ffff5cfc987 in iocshBody (pathname=0x7fffffffde25 "iocBoot/iocbl12-SampleCamera/st.cmd", commandLine=0x0) at ../../../src/libCom/iocsh/iocsh.cpp:771
#17 0x00007ffff5cfccaa in iocsh (pathname=0x7fffffffde25 "iocBoot/iocbl12-SampleCamera/st.cmd") at ../../../src/libCom/iocsh/iocsh.cpp:835
#18 0x0000000000405c0b in main (argc=2, argv=0x7fffffffda88) at ../bl12-SampleCameraMain.cpp:17
Complexity comes for free, simplicity you have to work for.
- ADProsilica crashing on RHEL7 3.10.0-1127 Pearson, Matthew R. via Tech-talk
- Re: ADProsilica crashing on RHEL7 3.10.0-1127 Mark Rivers via Tech-talk
- RE: ADProsilica crashing on RHEL7 3.10.0-1127 Pearson, Matthew R. via Tech-talk
- Re: ADProsilica crashing on RHEL7 3.10.0-1127 Dunning, Michael via Tech-talk
- RE: ADProsilica crashing on RHEL7 3.10.0-1127 Mark Rivers via Tech-talk
- Re: ADProsilica crashing on RHEL7 3.10.0-1127 Wlodek, Jakub via Tech-talk
- Re: ADProsilica crashing on RHEL7 3.10.0-1127 Johnson, Andrew N. via Tech-talk
Re: StreamDevice "type punning" floating point conversion Eric Norum via Tech-talk
<2020>
2025
2026
Error in quadEM Siddons, David via Tech-talk
<2020>
2025
2026
