Subject: Re: ADDexela hardware
To: John Dobbins <[email protected]>
Date: Wed, 14 Oct 2020 23:44:10 +0000
Hi John,
> Is the Dexela library provided by Perkin Elmer dependent on the specific Camera Link card in these computers? I assume yes but wanted to check.
I assume so, but I am not sure.  When you run the MSI installer presumably that installs the driver for the Camera Link card.  I doubt if you could substitute cards and drivers and have their library work, but I guess it's possible.
> Are replacement camera link cards available?
I think that is a question for Varex.
> I see that ADDexela mentions SDK version 1.3.1.0.  Where did this come from? Varex?
It came from Varex via this line in an e-mail I received from Keith Dowling at Varex on July 17, 2020.
> Our new CMOS software was delayed by a few days but is now available and can be downloaded from: https://vareximagpub.sharepoint.com/:f:/g/EpbONhWBk41Bk-E70MJStcIBhnUxjYGYqnY3rFn0OAyf3A.
I just checked and that link is still valid.
> Does it require a new camera link card?
Not that I know of.  I don't actually own a Dexela detector, so I was not able to test that new version of the SDK, except to see that it builds.  That is partly why I have not tagged a new release since updating the SDK version.  There are Dexela detectors at the APS, but I doubt if anyone has tried the master branch.
If you can test it that would be great, and then I'll tag a new release.
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Wednesday, October 14, 2020 12:39 PM
To: [email protected]
Subject: ADDexela hardware
The documentation for ADDexela reads:
"The driver is based upon the Dexela library provided by Perkin Elmer."
and
"This driver has been tested with the following detectors
  *   Dexela 1512 with CameraLink frame grabber"
I have two Dexela 2923 running areaDetector.   Is the Dexela library provided by Perkin Elmer dependent on the specific Camera Link card in these computers? I assume yes but wanted to check.  Are replacement camera link cards available?  I see that ADDexela mentions SDK version 1.3.1.0.  Where did this come from? Varex? Does it require a new camera link card?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu<http://www.chess.cornell.edu>
ADDexela hardware John Dobbins via Tech-talk
Prev: caQtDM Testflight (Apple) Brands Helge (PSI) via Tech-talk
Next: Re: caQtDM Testflight (Apple) Brands Helge (PSI) via Tech-talk
Prev: ADDexela hardware John Dobbins via Tech-talk
Next: caQtDM Testflight (Apple) Brands Helge (PSI) via Tech-talk
