Subject: RE: Seeking config advice for smarAct MCS controller
To: 'Juliane Reinhardt' <[email protected]>, 'Torsten Bögershausen' <[email protected]>, "Jemian, Pete R." <[email protected]>
Date: Thu, 22 Oct 2020 20:59:56 +0000
Hi Juliane,
To reduce the number of messages output you can now comment out this line:
asynSetTraceMask("MCS_ETH", 0, ERROR|DRIVER|FLOW)
If you do that do you see this message more than once, or do you only see it once when the IOC starts?
SmarActMCSController(MCS): WARNING - detected unexpected characters on link (MCS_ETH); make sure you have a RAW (not TELNET) connection
It could be some stale characters left in a buffer.
Sent: Thursday, October 22, 2020 2:54 PM
To: Mark Rivers <[email protected]>; 'Torsten Bögershausen' <[email protected]>; Jemian, Pete R. <[email protected]>
Cc: [email protected]
Subject: Re: Seeking config advice for smarAct MCS controller
Hi Mark,
we switched to ASCII in the smarAct firmware and this morning we successfully moved the motor using caput/caget. However, now I am back to getting this error:
$ ../../bin/linux-x86_64/smarAct st_201.cmd
#!../../bin/linux-x86_64/smarAct
< envPaths
epicsEnvSet("IOC","iocSmarAct")
epicsEnvSet("TOP","/opt/epics/synApps/synApps_6_1/support/motor-R7-1/modules/motorSmarAct/iocs/smarActIOC")
epicsEnvSet("MOTOR","/opt/epics/synApps/synApps_6_1/support/motor-R7-1")
epicsEnvSet("ASYN","/opt/epics/synApps/synApps_6_1/support/asyn-R4-36")
epicsEnvSet("SNCSEQ","/opt/epics/synApps/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("BUSY","/opt/epics/synApps/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("IPAC","/opt/epics/synApps/synApps_6_1/support/ipac-2-15")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
cd "/opt/epics/synApps/synApps_6_1/support/motor-R7-1/modules/motorSmarAct/iocs/smarActIOC"
dbLoadDatabase "dbd/smarAct.dbd"
smarAct_registerRecordDeviceDriver pdbbase
cd "/opt/epics/synApps/synApps_6_1/support/motor-R7-1/modules/motorSmarAct/iocs/smarActIOC/iocBoot/iocSmarAct"
## motorUtil (allstop & alldone)
dbLoadRecords("/opt/epics/synApps/synApps_6_1/support/motor-R7-1/db/motorUtil.db", "P=cosmic:")
# Uncomment one of the following lines for MCS or MCS2 controller
< smaractmcs_201.iocsh
### Motors
# Motors substitutions, customize this for your motor
dbLoadTemplate "motor.substitutions.smaractmcs_201"
# Configure each controller
#origvalues# drvAsynIPPortConfigure("MCS_ETH","192.168.1.17:2102",0,0,0)
drvAsynIPPortConfigure("MCS_ETH","192.168.168.201:5000",0,0,0)
asynSetTraceIOMask("MCS_ETH", 0, ESCAPE|HEX)
# Controller port, asyn port, number of axis, moving poll period, idle poll period
# smarActMCSCreateController(const char *motorPortName, const char *ioPortName, int numAxes, double movingPollPeriod, double idlePollPeriod);
smarActMCSCreateController("MCS", "MCS_ETH", 1, 0.020, 1.0)
2020/10/22 12:47:00.895 MCS_ETH asynManager::queueLockPort locking port
2020/10/22 12:47:00.895 MCS_ETH asynManager::queueLockPort created queueLockPortPvt=0x5576af1c87e0
2020/10/22 12:47:00.895 MCS_ETH asynManager::queueLockPort created queueLockPortPvt=0x5576af1c87e0, event=0x5576af1c8800, mutex=0x5576af1c88b0
2020/10/22 12:47:00.895 MCS_ETH asynManager::queueLockPort taking mutex 0x5576af1c88b0
2020/10/22 12:47:00.895 MCS_ETH asynManager::queueLockPort queueing request
2020/10/22 12:47:00.895 MCS_ETH lockPort
2020/10/22 12:49:11.561 MCS_ETH -1 autoConnect
2020/10/22 12:49:11.561 MCS_ETH set Eos 1
\n
0a
2020/10/22 12:49:11.561 MCS_ETH unlockPort
2020/10/22 12:49:11.561 MCS_ETH lockPort
2020/10/22 12:49:11.562 Attempting to connect to 192.168.168.201:5000  reason:0  fd:-1
2020/10/22 12:49:31.556 MCS_ETH addr -1 queueRequest priority 3 not lockHolder
I can still caget in another terminal and get a response.
I'm not aware of any changes since it worked (except from logout/login to the computer). Another controller of the same kind, that it connected on a different ip port (not started at the same time), works just fine.
Any suggestions?
Juliane
On 10/20/20 05:15, Mark Rivers wrote:
This doesn't seem to be a good thing.
The axis number is the EPICS axis number - it must start with 1.
That is not true.  EPICS axis numbers for model 3 drivers start with 0.
The example IOC for the smartAct MCS demonstrates that:
# Controller port, axis number, controller channel
# smarActSCUCreateAxis(const char *motorPortName, int axisNumber, int channel)
smarActSCUCreateAxis("SCU1", 0, 0);
smarActSCUCreateAxis("SCU1", 1, 1);
smarActSCUCreateAxis("SCU1", 2, 2);
smarActSCUCreateAxis("SCU2", 0, 0);
smarActSCUCreateAxis("SCU2", 1, 1);
smarActSCUCreateAxis("SCU2", 2, 2);
So does the Newport XPS example IOC:
# XPS asyn port,  axis, groupName.positionerName, stepSize
XPSConfigAxis("XPS1",0,"FINE.X",             100000) # VP-25XL
XPSConfigAxis("XPS1",1,"FINE.Y",              50000) # VP-5ZA
XPSConfigAxis("XPS1",2,"THETA.POSITIONER",     2000) # URS75CC
XPSConfigAxis("XPS1",3,"COARSEX.POSITIONER",   2000) # ILS200CC
XPSConfigAxis("XPS1",4,"COARSEY.POSITIONER",   2000) # ILS200CC
XPSConfigAxis("XPS1",5,"COARSEZ.POSITIONER",   5000) # IMS300CC
We believe we have found Juliane's problem.  This is the asynTrace output when the axis is being created.
2020/10/19 16:24:35.487 192.168.168.201:5000 flush
2020/10/19 16:24:35.487 192.168.168.201:5000 write.
2020/10/19 16:24:35.487 192.168.168.201:5000 write 7
:GCLS0\n
3a 47 43 4c 53 30 0a
2020/10/19 16:24:35.487 wrote 7 to 192.168.168.201:5000, return asynSuccess.
2020/10/19 16:24:35.487 192.168.168.201:5000 read.
2020/10/19 16:24:35.488 192.168.168.201:5000 read 4
\b\000\361\200
So the driver is sending an ASCII string, ":GCLS0\n".  But it is receiving a binary response: "\b\000\361\200".
Apparently there are 2 versions of the smarAct MCS firmware, one that does binary communication and one that does ASCII communication.  The EPICS driver only supports ASCII communication.  Juliane's controller apparently has the binary firmware version, so she needs to change the firmware on her MCS.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Torsten Bögershausen via Tech-talk
Sent: Tuesday, October 20, 2020 7:01 AM
To: Jemian, Pete R. <[email protected]>; EPICS Tech Talk <[email protected]>; Reinhardt, Juliane <[email protected]>
On 20/10/20 01:15, Jemian, Pete R. via Tech-talk wrote:
Here's a question from Juliane Reinhardt, ALS:
  > anyone having some advice for connecting motors to a smarAct MCS
controller? What does the channel number mean? Our .iocsh file looks
like this
### Motors
# Motors substitutions, customize this for your motor dbLoadTemplate
"motor.substitutions.smaractmcs_201"# Configure each controller
#origvalues#
drvAsynIPPortConfigure("MCS_ETH","192.168.168.201:5000",0,0,0)#
poll period # smarActMCSCreateController(const char *motorPortName,
idlePollPeriod); smarActMCSCreateController("MCS", "MCS_ETH", 1,
0.020, 1.0)# Controller port, axis number, controller channel #
smarActMCSCreateAxis(const char *motorPortName, int axisNumber, int
channel)
smarActMCSCreateAxis("MCS", 0, 0);
The channel is the axis number inside the controller - I don't know if they start counting at 0 ?
Not having such a controller, I would speculate and try smarActMCSCreateAxis("MCS", 1, 0);
Juliane Reinhardt, PhD
Project Scientist | ALS Computing Group
Blg. 15-337E | phone: 510-486-4313
[email protected]
Lawrence Berkeley National Lab
Seeking config advice for smarAct MCS controller Jemian, Pete R. via Tech-talk
Re: Seeking config advice for smarAct MCS controller Torsten Bögershausen via Tech-talk
RE: Seeking config advice for smarAct MCS controller Mark Rivers via Tech-talk
Re: Seeking config advice for smarAct MCS controller Juliane Reinhardt via Tech-talk
Prev: Re: Seeking config advice for smarAct MCS controller Juliane Reinhardt via Tech-talk
Next: RE: Seeking config advice for smarAct MCS controller Mark Rivers via Tech-talk
Prev: RE: Seeking config advice for smarAct MCS controller Mark Rivers via Tech-talk
Next: Supported 'Scopes? Johnson, Andrew N. via Tech-talk
