1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: LabView-EPICS Integration using SoftIoc
From: "Mostafa, Jalal \(IPE\) via Tech-talk" <[email protected]>
Date: Mon, 2 Nov 2020 14:31:48 +0000
Hi Mark,
Thank you for correcting me! Do you know how I can make I/O Intr work with CA Links?
Best,
Jalal
Sent: Monday, November 2, 2020 3:21:04 PM
To: Mostafa, Jalal (IPE)
Cc: [email protected]
Hi Jalal,
I don't know anything about EPICS/LabView interfaces, so I cannot comment on that.
However, this statement in your message is incorrect:
> I/O Intr are not available on a softIoc, so the developer has to use periodic SCAN.
That is not true at all.  I/O Intr scanning is not limited to hardware interrupts, it can be used with low-level driver polling.  Many of the EPICS modules use this: modbus, areaDetector, quadEM, etc.  The asyn driver can poll the device and then do callbacks to device support for I/O Intr scanned records.  This can be done at kHz rates, and you don't need to change the SCAN periods.  Often the driver will only do the callback when the value changes, but it can do the callbacks on every poll if desired.
From: Tech-talk <[email protected]> on behalf of Mostafa, Jalal (IPE) via Tech-talk <[email protected]>
Sent: Monday, November 2, 2020 7:44 AM
To: [email protected]
Subject: LabView-EPICS Integration using SoftIoc
Hi all!
We have many systems from NI that we would like to integrate with EPICS
for the KATRIN experiment (katrin.kit.edu)
The old control system was written in LabView but we would like to
replace it with EPICS without rewriting the code again. Therefore, we
are looking for a nice LabView-EPICS integration.
We have seen two options for LabView:
- CALAB which does not work with realtime devices
- Official NI EPICS module. It is good but I can list several problems:
huge loss of EPICS features (it is only an implementation of CA plus
alarming, the other metadata and configuration fields are not available)
- not very developer-friendly (adding/removing PVs relies on shared
variables so it is time consuming)
Another two solutions we thought of:
1. Using AsynDriver and communicate with the realtime device using a TCP
protocol
2. Running an EPICS server on the realtime device using NI EPICS module
then shadowing it with a SoftIoc using CA links.
(a softIoc server running with input and output records to read and
write to the original LabView EPICS server)
I have several concerns here:
- Am I missing any other way to integrate LabView with EPICS? I would
like to hear from your experiences.
- Although solution (1) is time consuming, I am in favor of it but let's
check if we can do it more easily with solution (2). Anyway, can the
experts comment on its feasibility?
- Solution (2): What do you think about performance? Alarms? I/O Intr
SCAN. How can I add custom SCAN periods?
Thanks for your help.
Best,
Jalal
Re: LabView-EPICS Integration using SoftIoc Mark Rivers via Tech-talk
LabView-EPICS Integration using SoftIoc Mostafa, Jalal (IPE) via Tech-talk
Prev: Re: LabView-EPICS Integration using SoftIoc Arnold, Ned D. via Tech-talk
Next: Re: LabView-EPICS Integration using SoftIoc Beranger six via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: LabView-EPICS Integration using SoftIoc Mark Rivers via Tech-talk
Next: Re: LabView-EPICS Integration using SoftIoc Mark Rivers via Tech-talk
