Subject: ADVimba camera timestamps
From: "Kinder, Steve \(STFC,DL,TECH\) via Tech-talk" <[email protected]>
Date: Wed, 4 Nov 2020 21:44:42 +0000
I have a Manta G235-B camera running on a RPi4 using ADVimba. We are interested in getting accurate timestamps per image from the camera. I've set the TimeStampMode PV to Camera. I hope this isn't too simple a question but which PV(s) should show a timestamp derived from the camera in this mode?
I have been trying to get derived ArrayData to have timestamps from the camera. To test this I am just doing:
$ camonitor -# 1 SHK78-TEST-01:CAM1:ArrayData
SHK78-TEST-01:CAM1:ArrayData   2020-11-04 16:23:00.867192 1 59
This is clearly too naive approach as the timestamps are just the system time. Any advice would be much appreciated.
Thanks
Steve
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Re: ADVimba camera timestamps Mark Rivers via Tech-talk
Prev: Re: Building ADVimba on Raspberry Pi Mark Rivers via Tech-talk
Next: Re: ADVimba camera timestamps Mark Rivers via Tech-talk
Prev: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
