1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Nov 2020 15:46:14 +0000
Hi all.
Buffer size is 48 because the device sends waveform data in lines so I read each line separately by reading 48 bytes, If I request ADC 200 for example I receive 200 lines where each line is 48 bytes. I even did a test where I used a buffer size of 1M to receive the full 20000 lines and still got the same error.
Regarding EPICS waveforms, what I meant is variable length from the client side; For example I set a buffer size in a PV and based on that PV value I read a specific length so that a plotter for example reads data with that specific length only. Does NORD achieve this? If yes, how does asyn access individual record's fields?.
Best Regards,
Abdalla.
Sent: Tuesday, November 3, 2020 7:18 PM
To: Mark Rivers <[email protected]>; Abdalla Ahmad <[email protected]>; [email protected] <[email protected]>
On 11/3/20 8:49 AM, Mark Rivers via Tech-talk wrote:
> -          I don’t think EPICS supports variable length waveform records.  You need to create the waveform record in dbLoadRecords with a size that is the largest you plan to use.  That is what areaDetector does with NDPluginStdArrays.
To clarify, waveform records have a _maximum_ size which is fixed
on initialization (eg. NELM).  Actually size (NORD) has long been
changeable at runtime in the range [0, NELM].
Some caveats about NORD==0 apply wrt. CA specifically (works fine with PVA).
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Abdalla Ahmad via Tech-talk
RE: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Michael Davidsaver via Tech-talk
Prev: caQtDM V4.3.0 Brands Helge (PSI) via Tech-talk
Next: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Michael Davidsaver via Tech-talk
