The ADEiger documentation reads:
"Status Parameters Polling
A few status parameters are read every time the ReadStatus PV is processed. A high rate polling causes issues, sometimes causing the detector to hang when, in conjunction, a parameter is set to an invalid value."
Can someone say what a "high rate" would be? 0.1 Hz, 1 Hz, 10 Hz? Other?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
- Re: ADEiger Status Parameters Polling Bruno Martins via Tech-talk
Re: device support for Keithley 428 Current Amplifier Johnson, Andrew N. via Tech-talk
GPIB remote control Mark Rivers via Tech-talk
<2020>
2025
2026
caQtDM V4.3.0 Brands Helge (PSI) via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
