1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: device support for Keithley 2450
From: "Siddons, David via Tech-talk" <[email protected]>
To: "Brown, Garth" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 26 Nov 2020 19:36:57 +0000
Hi Garth,
   Thanks for responding. Yes, please, I'd like to take a look at what you have. I have a specific set of test measurements I want to automate, which sounds similar to what you did.
Pete.
Sent: Wednesday, November 25, 2020 12:59 AM
To: EPICS Tech Talk <[email protected]>; Siddons, David <[email protected]>
I have a streamdevice based IOC talking to their similar 2612. My code wouldn't be directly useful to you, but depending on how you plan to use the 2450, the approach might suit you. They support a flavor of Lua with their own extensions that they call TSP. It was easy to learn. Console input/output from a TSP program can be used to write your own commands which interface with streamdevice. I used that interface for initialization and setting parameters. The TSP program executes a complicated series of measurements with timing requirements and 100+ data points, then sends the set of data back to streamdevice asynchronously.
On the other hand, if you want it for a general purpose lab instrument, this approach might not be flexible enough.
Garth
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Tuesday, November 24, 2020 6:28 AM
Subject: device support for Keithley 2450
HI Tech-Talkers,
Does anyone have support for the Keithley 2450 SourceMeter?
THanks,
Pete.
Re: device support for Keithley 2450 Brown, Garth via Tech-talk
device support for Keithley 2450 Siddons, David via Tech-talk
Prev: Re: calcout record, CP link, Cached Puts Michael Davidsaver via Tech-talk
Next: Alarm indicator in CSS Donny Domagoj Cosic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: device support for Keithley 2450 Brown, Garth via Tech-talk
Next: Re: device support for Keithley 2450 Brown, Garth via Tech-talk
