Subject: RE:RE:Alarm indicator in CSS
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: GAGET Alexis <[email protected]>
Cc: [email protected]
Date: Tue, 01 Dec 2020 11:01:32 +0100
Hi Alexis,
Thank you very much for your response. I was able to get it works based on the information you provided. I will continue working on the BEAST installation, any help from the community would be greatly appreciated, but at least I got some basic functionality using your approach.
Donny Domagoj Cosic
 Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
Dana 27.11.2020 15:14, GAGET Alexis je napisao(la):
BEAST installation is quite complicated but I know that Kay Kasemir (I
think) is working on a new version based on Kafka, maybe he can tell
you more about it.
1/ Yes the field VAL (the default value) will be at 0 but the field
SEVR will have the value you are looking for.
caget PV1
0
caget PV1.SEVR
NO_ALARM
You can use PV1.SEVR in the "PV name" in CSS. Also most of the widget
can natively handled the SEVR field, "alarm sensitive" option have to
be checked.
2/ No it means that the field SEVR will take the maximum level of
severity of the different input
record(calc, "PV1") {
     field(DESC, "global alarm severity")
     field(CALC, "0")
     field(INPA, "PV2.SEVR CPP MS")
     field(INPB, "PV3.SEVR CPP MS")
i.e. :
PV2.SEVR= NO_ALARM
PV3.SEVR= NO_ALARM
---> PV1.SEVR= NO_ALARM
PV2.SEVR= MINOR
PV3.SEVR= NO_ALARM
---> PV1.SEVR= MINOR
PV2.SEVR= MINOR
PV3.SEVR= MAJOR
---> PV1.SEVR= MAJOR
If you need more level than NO_ALARM, MINOR, MAJOR, you can use as you
said the CALC  record as a simple logical expression, but you will
lose the Alarm functionnality in CSS.
Cheers
Alexis
De : Donny Domagoj Cosic [[email protected]]
Envoyé : vendredi 27 novembre 2020 14:14
À : GAGET Alexis
Cc : [email protected]
Objet : RE:Alarm indicator in CSS
Hi Alexis,
Thank you for your response. I am not using BEAST because I was not able to get it to work correctly (is there any tutorial or information on how
to set it up?)
I tried your approach and it is a very good idea, thank you. Could you
just clarify a few things for me.
1. With the CALC field set to "0" isnt the output always "0"? Should the
CALC field be a logical expression with an OR between all inputs?
2. You use the MS field which I am guessing only signals when a MAJOR
alarm is triggered. Is it possible to get an output for any value of
SEVR except NO_ALARM?
Thank you once again,
Donny Domagoj Cosic
Dana 27.11.2020 10:28, GAGET Alexis je napisao(la):
Hi Donny,
Are you using an alarm server (BEAST) or just using a simple LED in CSS
In Beast I think you have the possibility to agregate the alarm
easily. Expert will answer you better than m.
Otherwise a way to do it with the database record:
record(calc, "$(MyMarvelousPV):Defects") {
    field(CALC, "0")
    field(INPA, "C2TS:COND:DefectsSecuBox1.SEVR CPP MS")
    field(INPB, "C2TS:COND:DefectsSecuBox2.SEVR CPP MS")
    field(INPC, "C2TS:COND:DefectsTemp.SEVR     CPP MS")
    field(INPD, "C2TS:COND:DefectsVac.SEVR      CPP MS")
    field(INPE, "C2TS:COND:DefectsRFPow.SEVR    CPP MS")
    field(INPF, "C2TS:COND:DefectsRFSrc.SEVR    CPP MS")
    field(INPG, "C2TS:COND:DefectsPUPM.SEVR     CPP MS")
The MS field (for Maximize Severityà means that my PV
$(MyMarvelousPV):Defects will have the field SEVR (severity) of the
higher severity of my inputs.
After that you can display easily your $(MyMarvelousPV):Defects in CSS.
cheers,
Alexis GAGET
CEA Saclay - DRF/Irfu/DIS/LDISC
[email protected]
De : Tech-talk [[email protected]] de la part de Donny
Domagoj Cosic via Tech-talk [[email protected]]
Envoyé : vendredi 27 novembre 2020 08:43
À : [email protected]
Objet : Alarm indicator in CSS
Hello,
I am still relatively new to EPICS, but I am slowly building up the
system in our lab. In many of the presentations about EPICS I see a
nice
alarm panel with LED displays that turn on when an alarm is raised. I
have been trying to implement this but I am having some difficulties.
I set alarm levels in my IOC for various sub systems such as radiation,
vacuum etc. and now I would like to have a general indicator in CSS
that
will indicate an alarm has been raised in any of these sub systems. So, for example, if any of the radiation probes trigger an alarm, a general
indicator will signal this to the user as an LED in CSS.
Is there any tutorials on how I would implement such a indicator or
would you be able to provide me with a overview on how to implement it?
Thank you,
Donny Domagoj Cosic
Alarm indicator in CSS Donny Domagoj Cosic via Tech-talk
RE:Alarm indicator in CSS GAGET Alexis via Tech-talk
RE:Alarm indicator in CSS Donny Domagoj Cosic via Tech-talk
RE:RE:Alarm indicator in CSS GAGET Alexis via Tech-talk
Prev: Ignore a welcome message in a telnet connection using StreamDevice Abdalla Ahmad via Tech-talk
Next: Re: Ignore a welcome message in a telnet connection using StreamDevice Ralph Lange via Tech-talk
Prev: RE:RE:Alarm indicator in CSS GAGET Alexis via Tech-talk
Next: ioc startup file installation Felix Krämer via Tech-talk
