1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: multiple USB devices in Asyn
To: "'Siddons, David'" <[email protected]>
Date: Tue, 8 Dec 2020 20:52:32 +0000
Can you send the complete output when you start the IOC?
Sent: Tuesday, December 8, 2020 2:49 PM
Cc: [email protected]
Subject: Re: multiple USB devices in Asyn
Hi Mark,
  Here is the code. I tried to send the whole IOC, but your mailer rejected it.
Pete.
Sent: Tuesday, December 8, 2020 2:36 PM
To: Siddons, David <[email protected]>
Cc: [email protected] <[email protected]>
Hi Pete,
Where is the source code containing this driver?
almCreateEZ4Controller("ALM1", "IP1", "$(ALM_ADDR1)", 4, 200, 500)
From: Tech-talk <[email protected]> On Behalf Of Siddons, David via Tech-talk
Sent: Tuesday, December 8, 2020 1:13 PM
To: [email protected]
Subject: multiple USB devices in Asyn
I have a setup with two identical USB devices. They connect as ttyUSB0 and ttyUSB1. I tried to set up an asyn interface using the following commands:
drvAsynSerialPortConfigure("IP1", "/dev/ttyUSB0", 0, 0, 0)
asynSetOption("IP1", -1, "baud", "115200")
asynSetOption("IP1", -1, "bits", "8")
asynSetOption("IP1", -1, "parity", "none")
asynSetOption("IP1", -1, "stop", "1")
asynSetOption("IP1", -1, "clocal", "Y")
asynSetOption("IP1", -1, "crtscts", "N")
drvAsynSerialPortConfigure("IP2", "/dev/ttyUSB1", 0, 0, 0)
asynSetOption("IP2", -1, "baud", "115200")
asynSetOption("IP2", -1, "bits", "8")
asynSetOption("IP2", -1, "parity", "none")
asynSetOption("IP2", -1, "stop", "1")
asynSetOption("IP2", -1, "clocal", "Y")
asynSetOption("IP2", -1, "crtscts", "N")
# almCreateController(AllMotion port name, asyn port name, board address,
#                     Number of axes, Moving poll period (ms), Idle poll period (ms))
almCreateEZ4Controller("ALM2", "IP2", "$(ALM_ADDR2)", 4, 200, 500)
This fails, saying port ALM2 cannot be found. If I try to connect the second one also to ALM1, it complains that ALM1 is already registered.
If I comment out the first device, the second one (with port ALM2) comes up fine. How should I be doing this?
Pete.
Re: multiple USB devices in Asyn Siddons, David via Tech-talk
RE: multiple USB devices in Asyn Mark Rivers via Tech-talk
Prev: Re: multiple USB devices in Asyn Siddons, David via Tech-talk
Next: Re: multiple USB devices in Asyn Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
