1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: PV Beginner Tutorial
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 11 Dec 2020 12:03:46 +0100
On Fri, 11 Dec 2020 at 10:51, Thomas Kutz via Tech-talk <[email protected]> wrote:
I am trying to setup a small scenario to check what Epics is capable of. So far I managed to create a small db with records and calculations. Now I would like to define structured data with the pvDatabase capabilities.
Is there any beginners tutorial on how to create a db with structured data, and put/get values to it?
Here are some pointers...
Note that pvDatabase is a distinct context and ecosystem, and has not a lot of overlap with the classical EPICS IOC and its process database.
If you want to use the EPICS process database (with all the hardware devices it supports), but create structured data that combines data from your EPICS database into a pvAccess structure, have a look at QSRV. [1]
If you want to put a pvAccess server (serving out structured data) on top of your existing C++ application, have a look at PVXS. [2]
If you want to see a tutorial for the pvDatabase library, have a look at the pvDatabase tutorial. [3]
Cheers,
~Ralph
PV Beginner Tutorial Thomas Kutz via Tech-talk
Prev: PV Beginner Tutorial Thomas Kutz via Tech-talk
Next: Re: PV Beginner Tutorial Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
